wasabi
Member since December 2020
Post by wasabi on Dec 31, 2020 13:16:13 GMT -5
Hi there,
I'd like to create rings completely out of stone. I would prefer an organic, asymmetric, smooth finish to my rings, but I don't care for a super high polish.
Right now my idea is to cut out the shapes then rough shape them on my flat lap and diamond burs to round out the inside. I want to use a tumbler to shape and get a even polish on them. I am wanting to purchase a tumbler + grit for this project and would love some guidance.
Would a Lot o or rotary work best for this? It appeals to me that the Lot o take less time and materials, but I'm not sure that It will smooth out the edges as much as id like. Then again I can always shape them with the diamond burs. Also if I want an even, but not too glossy of a finish what grit should I go up to?
Anyway, any thoughts or advice would be much appreciated!
Thank you!
Post by Pat on Dec 31, 2020 13:40:30 GMT -5
I’ve made all-stone one piece rings. Didn’t use a tumbler. Used core drills and Genie. Jim Brown made a video of his setup. rockjunquie. What’s Jim’s RTH name?
Post by rockjunquie on Dec 31, 2020 13:42:03 GMT -5
I’ve made all-stone one piece rings. Didn’t use a tumbler. Used core drills and Genie. Jim Brown made a video of his setup. rockjunquie . What’s Jim’s RTH name? I believe it's @wampidytoo.
Post by Pat on Dec 31, 2020 13:49:56 GMT -5
Thanks. I’m looking for his video/photos of his rock rings.
wasabi
Post by wasabi on Jan 1, 2021 12:36:46 GMT -5
I’ve made all-stone one piece rings. Didn’t use a tumbler. Used core drills and Genie. Jim Brown made a video of his setup. rockjunquie. What’s Jim’s RTH name? How do you polish/grind the inside of the rings? Diamond burs and flex shaft? I’m just worried I won’t get an even polish
Post by rockjunquie on Jan 1, 2021 12:54:11 GMT -5
I’ve made all-stone one piece rings. Didn’t use a tumbler. Used core drills and Genie. Jim Brown made a video of his setup. rockjunquie . What’s Jim’s RTH name? Sorry, Pat. Got it wrong. It's actually. wyrock wampidytoo
Post by rockjunquie on Jan 1, 2021 12:55:38 GMT -5
I’ve made all-stone one piece rings. Didn’t use a tumbler. Used core drills and Genie. Jim Brown made a video of his setup. rockjunquie . What’s Jim’s RTH name? How do you polish/grind the inside of the rings? Diamond burs and flex shaft? I’m just worried I won’t get an even polish Hopefully Jim or someone else will help. I can't answer your question. Seeing how it's a holiday, give people some time to find your post.
Post by Pat on Jan 1, 2021 13:16:17 GMT -5
Thanks, Tela. I’ve sent him a message. Re polishing the inside, probably with cones. I’ll look through my stuff.
Post by rockpickerforever on Jan 1, 2021 15:46:11 GMT -5
How do you polish/grind the inside of the rings? Diamond burs and flex shaft? I’m just worried I won’t get an even polish Hopefully Jim or someone else will help. I can't answer your question. Seeing how it's a holiday, give people some time to find your post. Jim gave me one of his gorgeous stone rings some years back (2012? 2013?), so I know of what you speak. Thought I'd take a look for the tutorial I am sure he did, but so far, no luck. I am hindered by the fact that he deleted his original account, "wampidy," so I can't search using that name. His next account is wyrock, screen name "wampidytoo," which someone already mentioned.
I'll keep looking...
Post by rockpickerforever on Jan 1, 2021 16:18:14 GMT -5
Found this thread from 2014. Not a tutorial, per se (hence, why it was not found with other tut's), but described how he made rings out of "ply-rocks," lol. Slabs of rock glued together. Trying to be humble about this ring
Will keep looking...
