reeniebeany
Rotary Only
Member since January 2020
Post by reeniebeany on Jan 17, 2021 20:24:01 GMT -5
Vibratory If you are running 120/220 for 2 days then running 120/220 for another 2 days why do a clean/rinse in between? Why not just add more grit and water sprays?
Is it because you get too much slurry?
Post by greig on Jan 17, 2021 23:23:33 GMT -5
I don't have a vibe tumbler but it makes no sense to me. I find it hard to believe the grit would be worn down after 2 days and if it is then it is just a finer grit. I watch this thread with interest.
Post by rmf on Jan 18, 2021 6:00:40 GMT -5
Well the issue with a vib tumbler is that you can build up so much mud that the rotation action stops. This is more a problem the coarser the grit.
reeniebeany
Rotary Only
Post by reeniebeany on Jan 18, 2021 11:13:35 GMT -5
Thanks! It is a physics thing then.
lordsorril
Member since April 2020
Post by lordsorril on Jan 18, 2021 12:02:01 GMT -5
Depending upon the grit size/amount and the hardness of the material you are vibing you can eventually produce so much slurry that regardless of the moisture concentration you will not get proper action since there is too much to stick to the rocks and it will sit at the bottom. Here is a photo @ 24hrs/500 grit in my UV-18...action is frozen and adding water does not resolve the issue (bowl is 50% full of Serpentinite-Mohs 3-6): need to cleanout at this point and restart.
dshanpnw
Member since December 2020
Post by dshanpnw on Jan 24, 2021 14:37:49 GMT -5
I had the same question. I am in the second 220 stage right now and I did not do a cleaning after the first, good rinse, but no soap run. The slurry does get pretty thick depending on what you are tumbling to the point where changing it is a good idea. Three to four days without a change the slurry would get pretty thick.
