agatewhisperer
Member since May 2020
Post by agatewhisperer on Feb 7, 2021 23:51:18 GMT -5
Ok, I have a problem. I find it very hard to cut lake superior agates. It's a special occasion when you find one and they're super cool as is. It's how I got interested in rocks. I came across this one without a lot going on and figured I couldn't make it worse so gave it a shot. Before... And after. Probably one of the highest domes I've made and was tough to photograph! Can see my arm in there too lol Thanks for looking!
Post by Pat on Feb 8, 2021 0:02:37 GMT -5
Wow! Cab doesn’t look at all like the rock!! You probably have the other half of the rock in its original form. Thanks!
Post by jasoninsd on Feb 8, 2021 0:09:41 GMT -5
This is exactly what drives me crazy about Fairburn Agates...what's hiding on the inside doesn't always make itself evident anywhere on the exterior! That stone is absolutely gorgeous! (And your arm is photogenic as well! )
Post by Pat on Feb 8, 2021 1:04:02 GMT -5
Hmmm, I don’t see see an arm... just fingers ... holding dop...
Post by jasoninsd on Feb 8, 2021 1:18:28 GMT -5
Hmmm, I don’t see see an arm... just fingers ... holding dop... Look at the reflection at the bottom of the cab.
Brian
Member since July 2020
Post by Brian on Feb 8, 2021 1:53:42 GMT -5
Are you sure that was from the same rock?!? I never would have guessed the inside would have looked that amazing based on the outside. That one was well worth cutting open!
Post by miket on Feb 8, 2021 10:34:55 GMT -5
Beautiful job!
Post by stephan on Feb 8, 2021 11:41:23 GMT -5
Nice work. You took the Michelangelo approach, I see:
“The sculpture is already complete within the marble block, before I start my work. It is already there, I just have to chisel away the superfluous material.”
Just substitute "cabochon" where it says "statue" and "agate" where it says "marble block." Oh, and I guess "grind" replaces "chisel."
Post by rmf on Feb 8, 2021 11:53:43 GMT -5
Not bad looking for being 1.2 billion years old.
NRG
Member since February 2018
Post by NRG on Feb 12, 2021 18:27:42 GMT -5
Superb
adrian65
Member since February 2007
Post by adrian65 on Feb 12, 2021 22:56:25 GMT -5
What a transformation! From frog to prince! Beautiful!
Adrian
agatewhisperer
Post by agatewhisperer on Feb 13, 2021 0:22:11 GMT -5
Thanks everyone! I looked through the pile of LSA's tonight to try and find a weekend project. Will post if I can get my act together.
