Post by miket on Mar 11, 2021 11:11:18 GMT -5
Thanks for the tips. The rocks always seem to want to go to one side, I go down every so often and turn the vibe 180 degrees. Whether or not that helps I don't know but I do it anyway. I thought I had the bowl full enough but maybe I'll order some more ceramics and try more on the next run. There is one larger stone in there that may be impeding some of the movement, too. The ceramics always seem to line the wall and every once in a while one manages to escape!
Is the floor level? If the floor is not level I would assume it will draw everything to one side. Mostly. I've had the vibe on a workbench, on the cement floor in different parts of the garage, on two boards on the cement floor on the garage...always with the seemingly same results.
