rrod
Member since December 2020
Post by rrod on Mar 19, 2021 22:29:32 GMT -5
"They tumbled calcite and failed?" "…They tumbled calcite and died." Learned a good bit from this tumble so it was not all in vain. There was one piece with a flat (cut?) side that actually had a mirror shine right around the edge, so I know it's possible. I think I didn't give these enough time in 500 & 1k AO, given how tight I had the barrel packed with small media. If I get a hankering I may revisit these, but for now I want to try to fix my last labradorite tumble.
Post by Pat on Mar 19, 2021 23:25:15 GMT -5
Hmmmm... looks like they tumbled carrots!!
Benathema
Member since November 2019
Post by Benathema on Mar 20, 2021 0:12:26 GMT -5
Post by greig on Mar 20, 2021 9:18:00 GMT -5
I love seeing wins, but learn more from fails. I could never get a decent shine on calcite.
Post by Fossilman on Mar 20, 2021 9:48:20 GMT -5
Calcite is a fragile mineral..... I have never tumbled that material at all...
Post by stefan on Mar 20, 2021 18:08:51 GMT -5
For some stupid reason I think you need to to hand finish calcite with something like ZAM or some kind of rouge (probably not red). I wonder if Cerium oxide would work? Not a bad attempt
rrod
Post by rrod on Mar 20, 2021 19:36:11 GMT -5
I'm assuming you start carrots at 220? I'm sure doing things by hand or trying trickery like dry tumbling could work, but I see results like this and I think it's just a matter of needing to dial things in correctly. If these were a bit more… convincing, I might give 'em more of a go, but at this point I'd rather open up the 3lb barrel for trying an easy material like labradorite again
