ericabelle
Instagram acct: @erica_shoots_everything
Member since April 2021
Post by ericabelle on Apr 23, 2021 8:41:34 GMT -5
This may be a strange question, but is there a minimum or maximum temp that you can run your tumbler in? The reason I ask is because I got my tumbler (Thumler's Model B) in February and put it in an unheated shed. It did great even during below freezing temps, but that shed really heats up in the summer, easily getting above 100 degrees F in the heat of the summer. Should I move it?
Post by HankRocks on Apr 23, 2021 9:03:25 GMT -5
This may be a strange question, but is there a minimum or maximum temp that you can run your tumbler in? The reason I ask is because I got my tumbler (Thumler's Model B) in February and put it in an unheated shed. It did great even during below freezing temps, but that shed really heats up in the summer, easily getting above 100 degrees F in the heat of the summer. Should I move it? I run my 3 Model B's in the garage during the Summer and have measured in-garage temps as high as 95 degrees and never had any issues. I am in the Houston area. I would make sure that the tumblers have a decent bit of air space around them.
ericabelle
Post by ericabelle on Apr 23, 2021 9:07:40 GMT -5
HankRocks , oh that's awesome! I didn't want to move it because I have more room to make a mess in the shed!
Post by stefan on Apr 23, 2021 15:07:04 GMT -5
Thumler's motors are thermally protected so they shutdown before burning up. My Pellet stove uses Fasco motors (the exact same ones!) on the blower and exhaust fans. The stove easily reaches 250 to 300 degrees in the enclosure and I have never had one go bad.
Cackling Chick
I LOVE ROCKS! πππ»πͺ¨βοΈ
Member since March 2022
Post by Cackling Chick on Apr 12, 2022 23:32:26 GMT -5
I have the same concern, specifically a hot garage, but will be using a Lortone 33B. Anybody know how they do @ ~95Β° in a garage?
Post by jamesp on Apr 13, 2022 8:06:31 GMT -5
Georgia in a real hot greenhouse with no problems.
Cackling Chick
Post by Cackling Chick on Apr 13, 2022 8:32:38 GMT -5
jamesp Good to know! What tumbler do you have?
Post by perkins17 on Apr 13, 2022 9:14:40 GMT -5
I have the same concern, specifically a hot garage, but will be using a Lortone 33B. Anybody know how they do @ ~95Β° in a garage? This was actually the first question I asked on this forum! I think you'll be fine running it in the heat. Mine runs in the garage through the summer here in Washington state, and it gets pretty hot here.
jimaz
Member since July 2018
Post by jimaz on Apr 13, 2022 10:41:05 GMT -5
I run a Lortone 45C and a Lot-O in the garage through the summer in southern Arizona with no issues.
Post by greig on Apr 13, 2022 11:08:47 GMT -5
I installed two solar powered roof vents near the peak in my garage. They have a built in fan with a thermal switch, that turn on when hot inside. They are quiet and work like a charm. It used to get really hot in there.
Cackling Chick
Post by Cackling Chick on Apr 13, 2022 22:49:10 GMT -5
perkins17 Ha, you must be in Eastern Washington!! No way Western Washington gets hot long enough to be an issue. π Do you remove the motor's cover plate for additional ventilation in the summer?
Cackling Chick
Post by Cackling Chick on Apr 13, 2022 22:55:20 GMT -5
greig sounds like an attic fan which I definitely agree are great!!
Post by perkins17 on Apr 13, 2022 22:58:45 GMT -5
perkins17 Ha, you must be in Eastern Washington!! No way Western Washington gets hot long enough to be an issue. π Do you remove the motor's cover plate for additional ventilation in the summer? Yup, Spokane! It gets real hot up here. I did remove the plate last year but I think it'll be fine being left on.
Cackling Chick
Post by Cackling Chick on Apr 13, 2022 23:07:19 GMT -5
perkins17 Knew it! Former Western Washington resident here. ππ» Thanks for the tumbling tip!
Post by perkins17 on Apr 14, 2022 9:11:29 GMT -5
perkins17 Knew it! Former Western Washington resident here. ππ» Thanks for the tumbling tip! Cool! What city?
Post by jamesp on Apr 14, 2022 10:00:51 GMT -5
jamesp Good to know! What tumbler do you have? Homemade tumblers. one is a large unit that has 2 sets of shafts. A fast set for rough grind and a slow set for finish steps. The 2 speeds work real well.
Cackling Chick
Post by Cackling Chick on Apr 16, 2022 18:32:09 GMT -5
perkins17 Bellingham and more recently Federal Way. The latter not a desirable area. π
Cackling Chick
Post by Cackling Chick on Apr 16, 2022 18:33:22 GMT -5
Post by perkins17 on Apr 16, 2022 18:52:00 GMT -5
perkins17 Bellingham and more recently Federal Way. The latter not a desirable area. π I'm thinking of eventually moving over to the West side or central Washington. That's too bad that Federal way wasn't a good area. Reminds me of Yakima...
Cackling Chick
Post by Cackling Chick on Apr 16, 2022 22:34:03 GMT -5
perkins17 Western WA is a totally different vibe for sure.
