AQuartzLow
Member since November 2020
Post by AQuartzLow on Apr 29, 2021 20:05:06 GMT -5
Do you need the soft resin wheels for cabbing? Or can hard wheels (or lap discs) be used for all the shaping/polishing?
Post by hummingbirdstones on Apr 29, 2021 20:51:47 GMT -5
Do you need the soft resin wheels for cabbing? Or can hard wheels (or lap discs) be used for all the shaping/polishing? You can use all metal wheels if you want to. It will make it more difficult to round the dome though. The beauty of the soft resin is that it has some give and "drapes" over the dome of the cab making it infinitely easier to smooth and polish the stone.
AQuartzLow
Post by AQuartzLow on Apr 30, 2021 13:37:23 GMT -5
You can use all metal wheels if you want to. It will make it more difficult to round the dome though. The beauty of the soft resin is that it has some give and "drapes" over the dome of the cab making it infinitely easier to smooth and polish the stone. Thank you! I’ve been watching lots of videos on cabbing, but haven’t found any that use just the hard wheels/discs. I have a full set of hard discs (to polish slabs for a project), and the first 2 hard wheels and don’t want to shell out on additional wheels at the moment, ya know? ANYhoo...I’ll just give them a go!
Post by stardiamond on Apr 30, 2021 14:07:37 GMT -5
My first cabbing machine had worn 80 and 220 hard wheels. Next step was worn 400 grit wet sand paper on a belt sander with a spray bottle. Final step was tin oxide on a leather polishing pad on the end of the machine. This was the configuration I bought and I made a lot of cabs with it.
I worked better on some material than other. The main issue was undercutting. I buy johnsonbrothers soft wheels. They do a good job and cost half of Diamond Pacific.
