lotarocks445
it came
Sept 21, 2005 18:49:42 GMT -5
Post by lotarocks445 on Sept 21, 2005 18:49:42 GMT -5
i got my fire agate today from colorwright any suggestions where to start
it came
Sept 21, 2005 21:21:31 GMT -5
Post by docone31 on Sept 21, 2005 21:21:31 GMT -5
Yeah. With fire agate, the fire is layer specific. Proceed slowly. If it were me, I would start with 600 mesh on the first wheel. Observe the nodules for fire, and clarity. If a window shows classic fire, stop grinding! Go to 1200 and work out the scratches from the 600. If the fire shows real well when wetted, slowly open up the window untill you have a good dome. Fire agate has nodules that are actually layers, cutting too deeply can eliminate a complete layer. If that happens, go back to 600 and rough down to the next layer, opening up the window slowly. I would reccomend using the worst piece, or another type of agate to get the feel of grinding that way. It is different than cutting a calibrated cab. Most fire agates are flat on the dome, or really oval. The nodules dictate the grinding. I use cerium oxide for final polish. I use 1200 mesh, then 3600, then cerium oxide. After cutting the fire, then shape the cab. In fire agates the more fire, the more precious. With most fire agates, the piece of jewelery is made for the stone, rather than cutting the stone for the setting. Fire agates are wonderful, and in the right setting they are magnificant. Good luck.
lotarocks445
it came
Sept 21, 2005 22:19:03 GMT -5
Post by lotarocks445 on Sept 21, 2005 22:19:03 GMT -5
thanks for the advise i love fire agate. ill post pix when im done
it came
Sept 22, 2005 12:26:29 GMT -5
Post by stefan on Sept 22, 2005 12:26:29 GMT -5
cool- Like Doc said work slowly- If you've ever worked Boulder opal its kinda similiar- THe trick is to recognize the fire before your thru it! Stop often and inspect- Oh and bright light helps alot!
lotarocks445
it came
Sept 22, 2005 21:06:15 GMT -5
Post by lotarocks445 on Sept 22, 2005 21:06:15 GMT -5
here is a couple of ring size fire agate that i worked on today
lotarocks445
it came
Sept 22, 2005 21:07:10 GMT -5
Post by lotarocks445 on Sept 22, 2005 21:07:10 GMT -5
it came
Sept 22, 2005 21:15:08 GMT -5
Post by rockds on Sept 22, 2005 21:15:08 GMT -5
they look nice from what I can tell. More focus would be better. Where did u get them?
deepsouth
He who rocks last rocks best
Member since January 2004
it came
Sept 23, 2005 3:58:32 GMT -5
Post by deepsouth on Sept 23, 2005 3:58:32 GMT -5
Wow , never seen anything like it , thanks for showing
Jack
it came
Sept 23, 2005 8:32:04 GMT -5
Post by Cher on Sept 23, 2005 8:32:04 GMT -5
Looks like some nice fire in them.
it came
Sept 23, 2005 9:59:28 GMT -5
Post by stefan on Sept 23, 2005 9:59:28 GMT -5
You got it- Looks like you nailed those ! Nice job
it came
Sept 23, 2005 17:22:14 GMT -5
Post by Tweetiepy on Sept 23, 2005 17:22:14 GMT -5
WOW those are fantastic - How come Stefan took those pictures for you hehe
littlejimie
A rolling stone gathers no moss
it came
Sept 23, 2005 19:48:52 GMT -5
Post by littlejimie on Sept 23, 2005 19:48:52 GMT -5
Great looking piece of fire agate! Excellent!
it came
Sept 23, 2005 21:17:53 GMT -5
Post by parfive on Sept 23, 2005 21:17:53 GMT -5
Looks like Stefan's been gettin' his stones tumbled all over this site today.
fatrichie
Member since July 2004
it came
Sept 24, 2005 0:40:01 GMT -5
Post by fatrichie on Sept 24, 2005 0:40:01 GMT -5
I just won an EBAY auction for a pound of fire agate rough from Amys natural gems. I'll post some pics when it arrives.
it came
Sept 27, 2005 10:35:30 GMT -5
Post by stefan on Sept 27, 2005 10:35:30 GMT -5
What the heck- Pick on Stefan day- dang it I leave for a few days and my name and quality work is trashed all up and down this board- SHame on all of you- Good thing I have a thick skin (and head too!)
it came
Sept 27, 2005 17:33:24 GMT -5
Post by Tweetiepy on Sept 27, 2005 17:33:24 GMT -5
Stefan you're about to be "Godlike" we have to harp on you before you get that status and crush us all to smithereens! - Your work is awesome, it's your past photographic efforts that are, um, being debated!
it came
Sept 28, 2005 12:35:24 GMT -5
Post by stefan on Sept 28, 2005 12:35:24 GMT -5
Me GOd like? NO WAY How many posts to do that???
it came
Sept 28, 2005 12:50:48 GMT -5
Post by LCARS on Sept 28, 2005 12:50:48 GMT -5
Most digital cameras have a close-up or macro mode that you need to activate to get close-up photos to focus properly. Simple point & shoot mode doesn't always yeild the sharpest results since the camera has to be "told" what you are going for when taking a photo in order to automatically adjust to the shooting conditions. The photos above look like the cameras attempt to ignore what's right in front of it in favor of what it "thinks" you are trying to take a photo of (the back ground). Check the camera manual for the proper close-up shooting mode to use & observe the closest focal distance rule for your lens. Not every camera can get a sharp image closer that 8" from the subject. In that case it's better to shoot it from 12" away using the larger picture size & crop out your subject after. In addition to being a rock hound (amoung other things) I am also an ametuer photographer.
it came
Sept 28, 2005 13:45:37 GMT -5
Post by Tweetiepy on Sept 28, 2005 13:45:37 GMT -5
Some nameless rockhounds *cough* * Stefan* use a tripod to prevent camera shake (which is an excellent idea!) but then set up the tripod on the table where the tumbler is tumbling and vibrating and blame camera or batteries for blurry pictures. ;D *runs off before said nameless rockhound whips out ruby slippers & cries out in best Auntie Em voice "Dang you Tweetie, may you rot in Hell!"*
yeahda1
it came
Sept 28, 2005 15:47:16 GMT -5
Post by yeahda1 on Sept 28, 2005 15:47:16 GMT -5
fire agate is fantastic, like was said go slow and have patients, if you don't what you have is a little more experiance and another stone for the driveway lol
