rockrockrock
Member since August 2016
Post by rockrockrock on May 7, 2021 21:28:25 GMT -5
I have not yet stumped you wonderful folks here, but this may very do it. It has certainly driven me crazy the last five years. I'll describe this briefly and then answer any questions you may have. Thanks in advance for your insights. I make a consumer product of a very strange plastic called casein. It is derived from a milk derivative. They use to make jewelry out of this material, esp in Europe. Here's the problem. This stuff hates everything -- heat, sanding and ESPECIALLY water (it turns to mush). I cut all my materials with laser, then tumble them, dry, in a Raytech vibratory tumbler in 150-fit Aluminum Oxide, to remove char, debur the edges, and then radius the edges. It works like a champ. But this stuff? Naw. It warps and bends slightly. Even at 1.50 mm thick, it warps. I assume it's from the heat and friction of the grit. Any ideas how to get around this? It's driving me nuts. I appreciate your insights. Thank You, RRR
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on May 7, 2021 21:47:45 GMT -5
rockrockrock
Post by rockrockrock on May 7, 2021 21:56:48 GMT -5
Woofer, thank you. Will def explore.
sm
Post by stefan on May 8, 2021 5:50:59 GMT -5
Just a thought as the vibe will be moving this stuff pretty rapidly and build up some heat (as you clearly understand). Have you tried it in a rotary? I'm thinking corn cob or Walnut shell as a filler.
rockstock
Member since April 2019
Post by rockstock on May 8, 2021 6:44:31 GMT -5
I thought woofers links were going to be rockrockrocks previous threads on this. There's probably been at least 5 by now
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 8, 2021 7:42:34 GMT -5
I thought woofers links were going to be rockrockrocks previous threads on this. There's probably been at least 5 by now Correct
This subject should be asked once and then discussed in the same thread. Asking the same question in 6 threads is a little excessive.
Post by hummingbirdstones on May 8, 2021 8:59:57 GMT -5
rockrockrock
Post by rockrockrock on May 8, 2021 15:33:02 GMT -5
Thanks, will check it out. Yeah, just miserable stuff. I can do it by hand perfectly but want to mechanize so i can make more than $1.63 an hour. thanks, RRR
rockrockrock
Post by rockrockrock on May 8, 2021 15:34:31 GMT -5
Agreed, I'm always so busy that I was unaware of all those posts. I'll ask the mods to remove a few of them. RRR
