Post by rockjunquie on May 8, 2021 18:57:29 GMT -5
I have a super thick thunder egg that is domed already on one side. I know this sounds obvious, but should I put the groove in it before I finish the other side? It seems like it would be easier, but I am worried about cutting the grove in the wrong place.
Post by stardiamond on May 8, 2021 19:02:31 GMT -5
I never cut groove. Once you mark the girdle line for the other dome it will tell you where to cut the groove.
Post by rockjunquie on May 8, 2021 19:04:12 GMT -5
I never cut groove. Once you mark the girdle line for the other dome it will tell you where to cut the groove. I've never marked for my girdle, but that sounds like a good idea.
Post by stardiamond on May 9, 2021 13:47:48 GMT -5
I've posted in the past about getting even girdles being difficult for me. I've figured it out. Mainly a lot of practice.
Before dopping, I put the preform face up on a metal template near the edge and pencil flat on the table top and rotate the preform against the pencil point. I get an even 3mm line.
Post by parfive on May 9, 2021 15:07:20 GMT -5
Unless you cut your grooves freehand with a Foredom or a Dremel, it’ll be a lot easier cutting the groove before the other dome.
