msuwabbit
Member since June 2020
Post by msuwabbit on May 10, 2021 15:24:15 GMT -5
I just acquired a really nice septarian geode in the rough. While I have a good grip on how to polish it, what should I use to clean and brighten the crystals in the interior?
Thanks!
David
Post by fernwood on May 10, 2021 15:25:04 GMT -5
Can you post a photo of it?
Post by HankRocks on May 10, 2021 15:37:36 GMT -5
I just acquired a really nice septarian geode in the rough. While I have a good grip on how to polish it, what should I use to clean and brighten the crystals in the interior? Thanks! David I believe that the crystals in most Septarian nodules are Calcite. Calcite is pretty soft so be careful cleaning. I would just use soap and water and a brush to see if that does any thing. As referenced, a picture would be good. Also are you planning on cutting it and then polishing the two halves?
Post by stefan on May 10, 2021 16:43:06 GMT -5
I clean mine with a long soak them a brushing (lightly) with some clean water and a little mild detergent.
msuwabbit
Post by msuwabbit on May 11, 2021 10:16:11 GMT -5
Here it is.
Post by rmf on May 11, 2021 14:05:55 GMT -5
What did you clean it with? It looks angry.
Post by fernwood on May 11, 2021 14:20:40 GMT -5
Beautiful rock. I would try using a soft brush, like a paint brush, and some detergent first. Or possibly a vinegar/baking soda fizz. If the crystals are not calcite. Those crystals look pretty fragile. Even the vibration during polishing could cause some to fall off.
Post by RWA3006 on May 11, 2021 18:27:12 GMT -5
Looks like a monster face. Use warm soapy water and a soft brush. No vinegar or acidic stuff should be used.
quartzilla
Member since April 2020
Post by quartzilla on May 15, 2021 20:18:14 GMT -5
Looks like a monster face. Use warm soapy water and a soft brush. No vinegar or acidic stuff should be used. Ha yeah! Looks kinda like Oogie Boogie!
Post by Pat on May 15, 2021 21:09:12 GMT -5
He's darling!!
Post by RickB on May 15, 2021 21:15:46 GMT -5
Here it is. Repost that photo in the fall with the other Halloween rocks that people will be posting then.
msuwabbit
Post by msuwabbit on May 16, 2021 13:50:36 GMT -5
Thank you all.
