stilllearning
Member since May 2021
Post by stilllearning on May 13, 2021 6:19:21 GMT -5
I got a new CR2 double tumbler and one of the rollers isn't turning smoothly, it making my barrels vibrate up and down a little bit. One roller is OK but don't know is if it's bent very slightly or the bearings at one end is out . But I'm newish to tumbling only been doing it with a single barrel machine and decided to get a double barrel one. I just don't no how much movement machines can take I want my machine to last and don't want to end up with a problem later down the line .I wonder if I should send it back as I can. Iv phoned suppliers he says there nothing to worry about as it's guaranteed for a year . But don't know if he's just saying that then bearings go and he says it's wear and tear. Please could someone give me advice ,as I don't have the money to waste I had to use my savings to buy this
Post by Fossilman on May 13, 2021 9:34:46 GMT -5
Hi and welcome... Please post this on the Rock Tumbling section, more people go to that section, than here.... They will fix you right up....
stonemon
Member since January 2017
Post by stonemon on May 13, 2021 10:03:13 GMT -5
Welcome to the forum!
Post by manofglass on May 13, 2021 11:19:07 GMT -5
I got a new CR2 double tumbler and one of the rollers isn't turning smoothly, it making my barrels vibrate up and down a little bit. One roller is OK but don't know is if it's bent very slightly or the bearings at one end is out . But I'm newish to tumbling only been doing it with a single barrel machine and decided to get a double barrel one. I just don't no how much movement machines can take I want my machine to last and don't want to end up with a problem later down the line .I wonder if I should send it back as I can. Iv phoned suppliers he says there nothing to worry about as it's guaranteed for a year . But don't know if he's just saying that then bearings go and he says it's wear and tear. Please could someone give me advice ,as I don't have the money to waste I had to use my savings to buy this Return the thing for a refund don’t mess with crap buy something that works
Post by As I in does tries! on May 19, 2021 16:01:53 GMT -5
Greetings and welcome from Scotland, I take it you mean an "Evans CR2" which is a UK made tumbler 240v/50hz. Evans CR2 Tumbler cleaning
