fencejumper
Member since May 2021
Post by fencejumper on May 16, 2021 9:10:47 GMT -5
Working with this material is a love hate relationship. mostly hate,but when love comes in?,she is sweet. the return rate on these is typically is 50/50. the more time you spend examining the slab,the better off you will be. good eyesight is key. i will hold the slab 8 inches above my stainless work bench and drop it flat. the pieces are what determines my design. IMG_7468 3 by paul forsythe, on Flickr IMG_7469 3 by paul forsythe, on Flickr
Post by rockjunquie on May 16, 2021 9:12:51 GMT -5
Absolutely beautiful! I do the drop thing, too, on a lot of material.
Post by hummingbirdstones on May 16, 2021 9:29:39 GMT -5
Those are gorgeous, Paul! My favorite one is the last picture right side.
Post by stardiamond on May 16, 2021 11:14:22 GMT -5
The strong patterned stuff.
Dropping a slab is probably more for entertainment. The unhealed and partially healed fractures are obvious and any line can be a fully healed fracture which may hold and may not. A surprise fracture is one where the pieces look like they were glued together.
Vugs are like sink holes in a slab, not clearly visible and will sometimes not break. When grinding a vug, three things can happen, it goes away, it gets better or it gets worse.
All a person can ask for is that a preform blows up as early as possible.
Post by opalpyrexia on May 16, 2021 11:44:44 GMT -5
Beautiful!
Post by stefan on May 16, 2021 11:47:09 GMT -5
The strong patterned stuff. Dropping a slab is probably more for entertainment. The unhealed and partially healed fractures are obvious and any line can be a fully healed fracture which may hold and may not. A surprise fracture is one where the pieces look like they were glued together. Vugs are like sink holes in a slab, not clearly visible and will sometimes not break. When grinding a vug, three things can happen, it goes away, it gets better or it gets worse. All a person can ask for is that a preform blows up as early as possible. Yea I stopped dropping slabs and started studying them. The more you look the better. I also spray them with water and watch what the water does. You will be amazed how a hidden fracture will bubble! Soft spots will absorb the water and appear dry. Often times problem areas show themselves when wet.
Brian
Member since July 2020
Post by Brian on May 16, 2021 13:04:23 GMT -5
Beautiful cabs! I’d say the unfrequent successes and frustrations are well worth it when they turn out like that!
