Post by stefan on May 16, 2021 17:50:55 GMT -5
Awesome tip! I wet the slabs with water and watch for bubbles!
Post by Peruano on May 16, 2021 20:32:21 GMT -5
Even with water, capillary action will cause the fracture to remain wet as the rest of the surface dries Another good clue comes from feeling the surface with a finger nail. At times only the finger nail can catch on the fracture. Tom
standles
Well all I got was a rock ... Cool!
Member since February 2021
Post by standles on May 16, 2021 22:41:35 GMT -5
I just drop the slab from 1 foot onto hard surface. If it cracks better i found it before starting to cab
Post by jasoninsd on May 17, 2021 20:17:11 GMT -5
@jadedvision - great topic for a thread! I have a tendency to do the "concrete drop" method. However, I have started taking notice of the capillary action as mentioned by Peruano since I use a water cooling saw. You mentioned the drop method can result in breakage along lines which normally would hold together. I noticed that the other day when I was dropping some material which fractured in what I believe was areas that would have held together when cabbing them...
SirRoxalot
Member since October 2003
Post by SirRoxalot on May 20, 2021 15:00:39 GMT -5
Wet the slab, and watch it dry. Fractures are pretty obvious. Carbide-tipped brick nippers take it apart with ease, or mark the cracks with a black marker if it’s valuable enough that you want to saw it.
Post by stephan on May 24, 2021 23:12:12 GMT -5
I just drop the slab from 1 foot onto hard surface. If it cracks better i found it before starting to cab I drop from about 3 feet, but not onto straight concrete, but carpeted (unpadded) concrete or linoleum.
Post by stephan on May 24, 2021 23:14:18 GMT -5
@jadedvision - great topic for a thread! I have a tendency to do the "concrete drop" method. However, I have started taking notice of the capillary action as mentioned by Peruano since I use a water cooling saw. You mentioned the drop method can result in breakage along lines which normally would hold together. I noticed that the other day when I was dropping some material which fractured in what I believe was areas that would have held together when cabbing them... Sometimes it will break along lines that may hold, but might undercut late in the process (think MHPJ).
