JR8675309
Member since August 2019
Post by JR8675309 on Jun 1, 2021 8:11:16 GMT -5
Good morning. I am looking for insight into my saw and/or blade after mall view the saw marks in two slabs I cut. After all it's nice material and I don't want to be wasting it by millimeters. If you know how to get the saw marks out that would be useful to. Also let me know if this thread should live in the equipment section please. The details and circumstances: I have an 8" drop (chop) saw from the 60's and I acquired it late 2019. It's manually cooled with mineral oil; as in, I hold the tubing coming from pump on the blade directly. I replaced the blade recently with a new MK-303 and this is the second cut with it and a new motor. With high hopes I cut this Biggs Jasper 2" x 4". It was slow going and the saw bogged down at one point when it was fully into the cut (1/2 way-ish). The material was HOT when done. Are the marks being made when the saw gets bogged down? Could I be introducing them by the way I lubricate the blade? Perhaps the pressure moves the blade some? I can change the lube method back distributing from a fixed location... the reason I do this manually is the old motor was having issues pushing the oil that high on the machine. I appreciate the input. res.cloudinary.com/jr8675309/image/upload/v1622551336/Biggs%20Jasper%20wet%206-2021.jpgres.cloudinary.com/jr8675309/image/upload/v1622551338/Biggs%20Jasper%20blade%20marks%206_2021.jpgres.cloudinary.com/jr8675309/image/upload/v1622551608/Biggs%20Jasperblade%20marks%20w%20Sugarbowl%206_2021.jpg
Post by jasoninsd on Jun 1, 2021 13:18:34 GMT -5
I have a 10" wet tile saw that I use to slab. I encountered the same thing with a brand new MK-303 blade when I cut softer material to start. Once I cut some harder material, the saw marks went away. I think (in my case) the new blade just needed to be "dressed"...
JR8675309
Post by JR8675309 on Jun 1, 2021 13:31:53 GMT -5
I have a 10" wet tile saw that I use to slab. I encountered the same thing with a brand new MK-303 blade when I cut softer material to start. Once I cut some harder material, the saw marks went away. I think (in my case) the new blade just needed to be "dressed"... Oh! One can only hope it just needs to be dressed!
Post by stefan on Jun 1, 2021 16:19:27 GMT -5
Could be any number of problems: the blade needs to be dressed, or the rock is vibrating in the vise, the alignment is off, blade is slightly dished. What worries me is the rock being hot after cutting. That should not be happening. Warm is ok but hot is not good. You need better oil flow to keep things cool (or a slower feed rate). Perhaps a slower feed will help with the marks
JR8675309
Post by JR8675309 on Jun 1, 2021 20:26:47 GMT -5
You are right! I forgot that the vice was vibrating and the wing nuts started unscrewing. I have never had that happen (and forgot all about it). Still that doesn't explain the first cut. Maybe I'm going to fast/pressing too hard.
Post by Peruano on Jun 1, 2021 20:33:15 GMT -5
Yes
Post by catmandewe on Jun 1, 2021 22:57:40 GMT -5
You did a great job with a hand fed 8" saw and loose clamps, slow it down and make sure the clamp is super tight, 8" is not really designed to be a slab saw.
Tony
JR8675309
Post by JR8675309 on Jun 2, 2021 7:46:37 GMT -5
You did a great job with a hand fed 8" saw and loose clamps, slow it down and make sure the clamp is super tight, 8" is not really designed to be a slab saw. Tony Thanks for the advice! Yes I keep trying to tell the spouse that I need a bigger saw
