stevenzawicki
Member since May 2021
Post by stevenzawicki on Jun 5, 2021 19:53:46 GMT -5
I was gifted a Chicago Electric (Harbor Freight) tumbler and apparently some sort of rock addicting drug.
4 weeks in. Went to check my rocks and the barrel wasn't turning. Broken Belt!!!
Is this common this quickly or am I doing something wrong??
My friend is now also encouraging me to get a Lot-O Tumbler, but they seem sold out everywhere. Are they usually hard to fine?
A new rock hound stuck in Kansas, Steve
Post by mohs on Jun 5, 2021 20:35:36 GMT -5
Some where way back in the archives I had posted about my Harbor Freight Tumbler I’ll be back if I find those pictures …mostly
Not sure you have the same one
Anyway mine was Constantly breaking that cheap little black belt
I had crafted a new pulley on the motor spindle I really lucked out because I found this secondhand pulley electrical part. Same spindle size hole. It was considerably more sturdy
Connecting that up then allowed me to use a super duper belt. Well a more heavy duty one.
It seemed to be a fix. I was only using it for fine grind. But my patience and space for tumbling were limited End up giving the tumblers away. But it seem to be a fix
Anyway those HF are known to a problem \ Good luck And Welcome to RTH
Ed
Post by greig on Jun 6, 2021 20:04:05 GMT -5
With the belt removed, spin your parts (hehe) by hand to see if there is resistance. No reason a belt fails that fast, except maybe it was made in China. Lube the bearings if necessary or do it anyway. Get another belt and continue with your tumble. Good luck.
Brian
Member since July 2020
Post by Brian on Jun 7, 2021 7:09:37 GMT -5
You may want to check to make sure everything is properly aligned. I’ve read that those tumblers often need to be re-aligned so that you are not putting unnecessary force on them.
Also check the spacing to make sure there isn’t too much tension on them. I had to turn up my Lortone when it was new to make sure everything was lined up and properly tensioned. In my case, the belt was too loose and I needed to move the motor farther away. The loose belt was rubbing on the sharp edge of the pulley.
gatorflash1
Post by gatorflash1 on Jun 8, 2021 13:21:36 GMT -5
I was gifted a Chicago Electric (Harbor Freight) tumbler and apparently some sort of rock addicting drug. 4 weeks in. Went to check my rocks and the barrel wasn't turning. Broken Belt!!! Is this common this quickly or am I doing something wrong?? My friend is now also encouraging me to get a Lot-O Tumbler, but they seem sold out everywhere. Are they usually hard to fine? A new rock hound stuck in Kansas, Steve Steve - I buy belts by the dozen and seem to break one every month or two on my large 15lb tumblers. They may have a larger load than they are designed for.
Post by fernwood on Jun 8, 2021 15:05:44 GMT -5
I replaced the belt with an O-ring before use. Have had no problems.
reeniebeany
Rotary Only
Member since January 2020
Post by reeniebeany on Jun 10, 2021 20:08:03 GMT -5
I also have the CE (dual drum). My hubby took off the end caps of the spindles so I can grease it. Otherwise it rubs and squeaks like crazy. Mine has a belt adjustment thingy that we needed to tighten after about a year. If yours has the same adjustment maybe it can be loosened up. A quick search shows possible belt replacements: www.amazon.com/Freight-Chicago-Electric-Rock-Replacement/dp/B01DUZLW76Not sure which those are for (single or dual), or which you have but it might not be that hard to find replacements. I don't think any of us here can help you with the rock addiction. Own it, embrace it, revel in it...
