reeniebeany
Rotary Only
Member since January 2020
Post by reeniebeany on Jun 24, 2021 22:32:20 GMT -5
It has been months and I couldn't wait for the UV-18 to be available, so I bought a UV-10. How far can you push it on rock size? The manual says 1.5 inches. Is that a pretty firm guideline?
I have gallons and gallons of things I want to polish that are in the 2-3 inch range.
Someday the 18s will be back in stock, but I wondered if I could slide the occasional bigger guy into the UV-10
I LOVE being able to open it up and watch it tumble. I now have earplugs hanging on the laundry room doorknob, cause it is lots louder than the rotaries. But DANG it is exciting!
Post by Rockindad on Jun 25, 2021 11:21:04 GMT -5
Bit of a trick question. If you are talking about an actual round/sphere-like rock then 2-1/2", maybe up to 2-3/4". Most of what we put in is irregular shapes like elliptical, palm stones, larger slices, etc. In those cases we pack it with pieces 1-1/2" to 2" by 4" plus. Basically if it can fit in the bowl and move around a bit you are good to go. The nice thing about the UV-10 is that you can run multiple large pieces and not have to worry about them brutalizing each other because there is also the toroidal movement in the bowl.
Post by manofglass on Jun 25, 2021 11:37:01 GMT -5
Oil that threaded rod now and then keep it from rusting
reeniebeany
Rotary Only
Post by reeniebeany on Jun 25, 2021 17:03:37 GMT -5
Thanks, that is helpful! More of them are probably elliptical than full round.
Post by broseph82 on Jun 25, 2021 20:34:59 GMT -5
Thanks, that is helpful! More of them are probably elliptical than full round. Just an FYI, smaller rocks always do better tumbling whether in a rotary or vibratory. I’ve done very large and small and the smaller rocks ALWAYS come out better. Less banging which causes frosting of the edges and more fluid motion. I know it’s tempting to do a bigger ones, but if you do make sure the majority are small and just a few larger ones. Play around with it all and see how you do. All trial and error
