Post by perkins17 on Jul 1, 2021 22:01:00 GMT -5
I am interested in purchasing a vibratory tumbler and was wondering if anyone would recommend buying the TV 5 or not recommend this model. Thank you in advance.
pizzano
Member since February 2018
Post by pizzano on Jul 1, 2021 23:09:38 GMT -5
A good little vibe for working with material after the rough stages have been accomplished.......once you get the hang of the whole vibe process.......great polisher.
Post by perkins17 on Jul 2, 2021 11:02:44 GMT -5
A good little vibe for working with material after the rough stages have been accomplished.......once you get the hang of the whole vibe process.......great polisher. Thanks!
afterburnt
Member since June 2021
Post by afterburnt on Jul 6, 2021 17:31:55 GMT -5
I got the one with two bowls. They both are scored so I just ordered a third bowl so I have one for each stage after stage one rotary tumbling. Maybe overkill but I don't have to worry about carryover now.
kyoti
Member since June 2020
Post by kyoti on Jul 7, 2021 11:17:57 GMT -5
I have both a 30 yr old and a brand new TV5. Both do a fabulous job of polishing up material. The newer one's bowl is a harder plastic, so bear in mind it'll make a quite a bit of noise.
Post by perkins17 on Jul 7, 2021 12:19:46 GMT -5
I have both a 30 yr old and a brand new TV5. Both do a fabulous job of polishing up material. The newer one's bowl is a harder plastic, so bear in mind it'll make a quite a bit of noise. Thanks! Would it damage your hearing if you were with it for long periods of time? It would be going in my garage and I don't want it to damage my hearing while I'm working on a project. The raytech website says that it is about 82 decibels. Is it close to that?
stewdogg
Member since January 2020
Post by stewdogg on Jul 7, 2021 12:46:31 GMT -5
I have a chair with a couple of rugs draped over it to dampen the sound when I have to be close to mine. I have also used a 5gal bucket for a muffler too. I have had good luck with my TV5 as well. The only issue I have is that now I want a bigger one...
Post by perkins17 on Jul 7, 2021 23:51:17 GMT -5
Thanks!
kyoti
Post by kyoti on Jul 8, 2021 8:26:02 GMT -5
perkins17 I'm not going to lie, it's pretty loud when I'm near it in the garage. I put on ear protection when I'll be near it for more then a few minutes. The sound will change when you get the slurry just right and it'll be a bit more quiet. The lid helps a lot to muffle the sound too.
Post by perkins17 on Jul 8, 2021 11:11:28 GMT -5
Ok. Thanks for the input.
afterburnt
Post by afterburnt on Jul 8, 2021 13:44:21 GMT -5
I have both a 30 yr old and a brand new TV5. Both do a fabulous job of polishing up material. The newer one's bowl is a harder plastic, so bear in mind it'll make a quite a bit of noise. Thanks! Would it damage your hearing if you were with it for long periods of time? It would be going in my garage and I don't want it to damage my hearing while I'm working on a project. The raytech website says that it is about 82 decibels. Is it close to that? I read that continuous low level noise is more damaging than intermittent loud noises. I make a contraption out of acoustic foam, basically a cylinder with a square panel on top. The tumbler sits on a square paver so the squares at the top and bottom allow for good ventilation and it really tames the noise.
Post by perkins17 on Jul 8, 2021 14:35:32 GMT -5
Thanks!
