Grit
Jul 9, 2021 19:19:10 GMT -5
via mobile
Post by perkins17 on Jul 9, 2021 19:19:10 GMT -5
I am currently running the poly plastics grit kit and will then be moving on to my local rock shops' polish. I think poly plastics is only 1200 aluminum oxide and have read on here that 14,000 aluminum oxide polish is a better polishing agent. Is Kingsley north's polish a good option? I saw they sold their silicon carbide and aluminum oxide at fairly low prices. Thanks!
Grit
Jul 9, 2021 22:20:28 GMT -5
Post by jasoninsd on Jul 9, 2021 22:20:28 GMT -5
I believe there are several people on here that would recommend Kingsley North's grit and polish. I think even more might recommend the grit and polish from The Rock Shed. I use theirs (they're local to me) and have had zero complaints about it. www.therockshed.com/grit.html
Grit
Jul 10, 2021 10:33:48 GMT -5
via mobile
jasoninsd likes this
Post by perkins17 on Jul 10, 2021 10:33:48 GMT -5
Thank you!
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Jul 10, 2021 11:43:51 GMT -5
Kingsley doesn't appear to have Aluminum Oxide Polish. They call their stuff Alumina Polish. I order from Kingsley all the time but I have never tried Alumina.
Brian
Member since July 2020
Post by Brian on Jul 10, 2021 11:59:07 GMT -5
Kingsley doesn't appear to have Aluminum Oxide Polish. They call their stuff Alumina Polish. I order from Kingsley all the time but I have never tried Alumina. Alumina is another name for aluminum oxide. Silica = silicon oxide Titania = titanium oxide Ceria = cerium oxide
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Jul 10, 2021 12:39:20 GMT -5
That is interesting ? A search of Kingsley for `Aluminum Oxide' only turns up 1 result for 1000 Prepolish The AO from Rockshed works exceptionally well, makes me afraid to try the `Alumina' from Kingsley ?
Brian
Post by Brian on Jul 10, 2021 12:44:43 GMT -5
That is interesting ? A search of Kingsley for `Aluminum Oxide' only turns up 1 result for 1000 Prepolish The AO from Rockshed works exceptionally well, makes me afraid to try the `Alumina' from Kingsley ? They list micro-alumina (https://kingsleynorth.com/micro-alumina.html) which has a particle size of 1-3 microns, which equates to 8,000-14,000 grit.
