lewy
Member since March 2020
Post by lewy on Aug 7, 2021 3:20:13 GMT -5
I have just aquired an thumlers ar2 tumbler,it has sat for a number of years and because i am in the tropics the rubber in the barrels has started to rot away and they both leak badly.is anyone using lortone barrels on thumler ar2 if so is there any mods needed and what lortone barrel do i need.I dont like the design of the thumblers barrel.thanks in advance
terryjh
Member since July 2021
Post by terryjh on Aug 8, 2021 9:02:46 GMT -5
inbtb
Member since May 2016
Post by inbtb on Aug 8, 2021 10:03:10 GMT -5
1 QT6 barrel will fit. Have not used that way it was just a size check.
Post by greig on Aug 8, 2021 18:45:59 GMT -5
I have used other brand barrels on a Lornone, so no reason it won't work the other way around. You might have to add guides so the barrels don't rub, but that isn't difficult.
Post by Mel on Aug 11, 2021 21:28:41 GMT -5
I've used a Lortone 3A barrel on my Thumler (I think an AR-1, AR-12? Their 3 pound version) for awhile due to a broken belt. Worked OK except it did rub a lot on the Lortone lid.
