chandler
Member since November 2020
Post by chandler on Aug 8, 2021 21:37:53 GMT -5
A friend gave me this rock. It had a lot of yellowing, so I soaked it in Iron-Out. Can you tell me what it is, please?
Post by perkins17 on Aug 8, 2021 22:33:01 GMT -5
A friend gave me this rock. It had a lot of yellowing, so I soaked it in Iron-Out. Can you tell me what it is, please? It appears to be a quartz vein in basalt to me. I tumbled a much smaller chunk that looked a lot like that.
chandler
Post by chandler on Aug 9, 2021 9:17:48 GMT -5
A friend gave me this rock. It had a lot of yellowing, so I soaked it in Iron-Out. Can you tell me what it is, please? Thank you! Do you have any idea what I could do with this? Break it up and tumble? Leave as is? It appears to be a quartz vein in basalt to me. I tumbled a much smaller chunk that looked a lot like that.
wpotterw
Member since September 2016
Post by wpotterw on Aug 9, 2021 10:28:21 GMT -5
A friend gave me this rock. It had a lot of yellowing, so I soaked it in Iron-Out. Can you tell me what it is, please? Looks like a quartz vein in a metamorphosed mudstone.
fuss
Post by fuss on Aug 12, 2021 0:30:34 GMT -5
Shale/Slate with white Calcite possibly as well, where is from? happen to have any Muriatic acid to test the suspected calcite?
chandler
Post by chandler on Aug 13, 2021 16:22:55 GMT -5
Vinegar didn't have any effect on it. A knife doesn't scratch it. I haven't tried muriatic acid.
I appreciate your answer.
Post by perkins17 on Aug 13, 2021 16:56:33 GMT -5
Vinegar didn't have any effect on it. A knife doesn't scratch it. I haven't tried muriatic acid. I appreciate your answer. Basalt is about a 6 on the hardness scale and quartz is seven. If you have some quartz, you could see if it scratches the basalt (I think) and the quartz. If I am wrong, it probably will not scratch the white stone.
Post by rmf on Aug 17, 2021 20:25:32 GMT -5
Go with Basalt and Quartz.
