Post by perkins17 on Aug 9, 2021 10:05:27 GMT -5
I am planning on buying a tile saw soon and learned that you can make tumbled preforms or flat cabachons. I only have a rotary tumbler right now and was wondering if I could start in 120/220 grit with lots of ceramics and tumble finish them. Thanks in advance!
Post by miket on Aug 9, 2021 10:47:56 GMT -5
I used to tumble preforms and cabs entirely through rotary and it is definitely possible. Now I use a Raytech TV-5 vibe tumbler ($88 on Amazon) which works well, too.
Post by perkins17 on Aug 9, 2021 11:20:38 GMT -5
I used to tumble preforms and cabs entirely through rotary and it is definitely possible. Now I use a Raytech TV-5 vibe tumbler ($88 on Amazon) which works well, too. Thanks! I was looking at that tumbler a while back before looking at flat laps.
Post by Mel on Aug 19, 2021 22:54:01 GMT -5
You can do anything you like it just depends on the results you're after If I'm in a mood, I'll cut preforms and run them through the vibratory tumbler, and for flat slabs of undetermined fate, they go in the rotary. Works not too shabby.
Post by stephan on Aug 19, 2021 23:03:01 GMT -5
Post by Mel on Sept 1, 2021 12:05:58 GMT -5
I will also be the first to admit that my rotary tumbled slabs end up as pendants or magnets, not stunning gemstones. However, as soon as someone tells me I can't do something......I'm probably going to do it.
Post by stefan on Sept 5, 2021 18:30:08 GMT -5
Yes yes yes. I do it all the time. I have preforms that just don't work out on the cabinet so into the tumble mix they go.
