Post by perkins17 on Aug 13, 2021 18:27:45 GMT -5
I am running a Lortone 33b and have gotten all sorts of grit stuck in the expired barrel shell and need ideas for cleaning it out. It drives me crazy whenever I see it. I scrubbed it down with dawn once but even that didn't get it perfect. All ideas are helpful and appreciated.
inbtb
Member since May 2016
Post by inbtb on Aug 13, 2021 19:53:09 GMT -5
What grit are you using? Where is grit? Is it laying in the bottom after clean out? How long of tumbling cycle are you running?
Post by perkins17 on Aug 13, 2021 20:47:28 GMT -5
What grit are you using? Where is grit? Is it laying in the bottom after clean out? How long of tumbling cycle are you running? I am using silicon carbide and aluminum oxide. It is stuck into the outside of the barrel.
dehinrichs
Member since September 2013
Post by dehinrichs on Aug 13, 2021 22:42:04 GMT -5
Try using an old toothbrush.
Post by quartz on Aug 13, 2021 22:43:22 GMT -5
How did grit get stuck on the outside of the barrel? I would think a good scrubby pad for dishwashing and some soapy water would work fine.
Post by perkins17 on Aug 14, 2021 12:11:11 GMT -5
Ok thanks!
