catfish
Member since August 2021
Post by catfish on Aug 17, 2021 13:09:47 GMT -5
How do you change the file size? Recommended that you start your file size at 800, but that looks too big. So I wanna cut it down to a little better than half of that size, but I can’t find out where to go to do it!
Thanks in advance for the help
Post by Tommy on Aug 17, 2021 13:53:25 GMT -5
How do you change the file size? Recommended that you start your file size at 800, but that looks too big. So I wanna cut it down to a little better than half of that size, but I can’t find out where to go to do it! Thanks in advance for the help Hi, it's actually quite easy ... just kidding ... it's not easy, it's a lot of steps. If you are on a PC or laptop - 1. Open the Cloudinary.com website and log in 2. Click on dashboard tab (top left) 3. Click on the gear icon for settings (top right-ish) 4. Click on "Upload" tab (left side next to "Account") 5. Scroll down to the "Upload Presets" area 6. Choose your active preset and click "edit" 7. Click "upload manipulations" tab (left side menu) 8. Click the word "edit" If you have done it correctly you should be seeing this pop-up box with slide controls: My example here is based on the width and I let the height be whatever it is to keep the scale the same, but play around with it till you get the incoming size and shape you want. Hope this helps!
catfish
Post by catfish on Aug 17, 2021 14:00:31 GMT -5
Thanks Tommy, I have an Apple phone and desktop, but I’ll try it anyway, I think I can get to it with this superior equipment, LOL! So far all I’ve been using is this iPhone.
Post by Tommy on Aug 17, 2021 14:03:42 GMT -5
Thanks Tommy, I have an Apple phone and desktop, but I’ll try it anyway, I think I can get to it with this superior equipment, LOL! So far all I’ve been using is this iPhone. All I've ever done it on is my desktop PC. I know that one of these days I'm going to have to tackle it on my phone but I'm putting that off as long as I can
catfish
Post by catfish on Aug 17, 2021 14:15:16 GMT -5
Tommy, it works on an Apple phone. I just had to make a few minor adjustments to find the proper links. And now I think I’m down to the right size. Now I need to know where to post all these pictures of my raw rock.
Post by rockjunquie on Aug 17, 2021 14:33:34 GMT -5
Tommy, it works on an Apple phone. I just had to make a few minor adjustments to find the proper links. And now I think I’m down to the right size. Now I need to know where to post all these pictures of my raw rock. Are you looking for an ID? If so put it in the ID section. If you are just sharing pics, put them here, unless they are specimens (destined for a collection), then you put them here.
rewdownunder
Member since March 2012
Post by rewdownunder on Sept 1, 2021 18:42:10 GMT -5
Tommy that is a first class set of clear instructions!! You make this board easy to work with Thank You
