Post by perkins17 on Aug 27, 2021 22:01:34 GMT -5
I have heard people use 47/60 in larger tumbler but never anyone using it in a 3 lb Lortone. Is it possible? Would it initiate faster grinding? Thanks in advance.
lordsorril
Member since April 2020
Post by lordsorril on Aug 28, 2021 8:17:08 GMT -5
I use #46 SiC in my 3lbs., (2 tbsp/lb.): takes a solid week to break down with Mohs 7 material, much much lower quantity of SiC with softer stones. My 12lb. lortones will eat 2 tbsp/lb. in about four-five days vs. seven in a 3lb. barrel--so I tend to add more.
Post by perkins17 on Aug 28, 2021 11:18:59 GMT -5
I use #46 SiC in my 3lbs., (2 tbsp/lb.): takes a solid week to break down with Mohs 7 material, much much lower quantity of SiC with softer stones. My 12lb. lortones will eat 2 tbsp/lb. in about four-five days vs. seven in a 3lb. barrel--so I tend to add more. Thanks for the information!
quartzilla
Post by quartzilla on Aug 28, 2021 23:33:10 GMT -5
I had trouble with it breaking down in my 33b. Even ran it extra days and there would still be abnormal amounts not breaking down. I’m gonna give it a whirl in my 6lb coming up quick.
Post by aDave on Aug 29, 2021 3:07:56 GMT -5
I had trouble with it breaking down in my 33b. Even ran it extra days and there would still be abnormal amounts not breaking down. I’m gonna give it a whirl in my 6lb coming up quick. FWIW, your 6lb barrel should have no problem whatsoever with the 46/70. I was also able to use it in my 45C before I transitioned to a QT66 for all of my coarse work. I think you'll like it.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Aug 29, 2021 9:16:24 GMT -5
I had trouble with it breaking down in my 33b. Even ran it extra days and there would still be abnormal amounts not breaking down. I’m gonna give it a whirl in my 6lb coming up quick. I have used 30 Grit in my QT66 for 3 years now it always breaksdown in a week for me
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Sept 7, 2021 17:39:54 GMT -5
Way Way Back when I only had a 3 pound Tumbler I built a Cleanout Sink with Grit recovery. Then I didn't mind too much if there was unused grit being cleaned out every week because I was still keeping and reusing it.
Post by perkins17 on Sept 7, 2021 18:53:56 GMT -5
I actually have an outdoor sink and am saving the grit. (Not enough to save yet though.)
gatorflash1
Post by gatorflash1 on Sept 8, 2021 9:38:48 GMT -5
I mixed it with 60 and the combination was successful on my agates, etc.
