thestripedone
does anyone use a 5 step polishing ....80,220,600,1500, then polishing
Member since January 2020
Post by thestripedone on Sept 1, 2021 15:45:58 GMT -5
I have an old lortone 33B tumbler and have been buying parts for it. now the motor died. any advice on whether I should replace all the parts including the motor, or buy a new one? any other small tumblers better, if so can you use the lortone barrels on other brands?
thanks Bruce (aka Ref)
JR8675309
Member since August 2019
Post by JR8675309 on Sept 1, 2021 16:07:20 GMT -5
How many other parts have been replaced? If significant, it may be worth the 37ish bucks for the motor, if it's in stock. I love mine and personally wouldn't run anything different.
What parts can be replaced on these? Is this everything? Drive axle and covers Bearings Motor Belt Pulley Collar thing on shaft (what IS that called??) Barrel, lid, inner lid, washer, nut x2
thestripedone
Post by thestripedone on Sept 7, 2021 15:50:33 GMT -5
thanks for the info. I'll see how many parts I need. probally cheaper to replace the motor and any other worn parts..I haven't checked what a new one would be. where do you suggest I buy the parts?
JR8675309
Post by JR8675309 on Sept 7, 2021 18:21:28 GMT -5
The Rock shed has the motor for 37 I think. They have the drive shafts and bearings as well
JR8675309
Post by JR8675309 on Sept 7, 2021 18:22:19 GMT -5
37 is way cheaper than new, of course, and no one has them in stock'
thestripedone
Post by thestripedone on Sept 10, 2021 7:41:47 GMT -5
thanks all for the suggestions
JR8675309
Post by JR8675309 on Sept 10, 2021 8:20:32 GMT -5
What did u wind up deciding?
thestripedone
Post by thestripedone on Sept 11, 2021 6:04:10 GMT -5
I decided to just replace parts...I've looked all over for a motor. everyplace I look is "out of stock" even kingsley North. what gives with that? Is Lortone not making them any more for the 33 machines I wonder? any suggestions? thanks, Bruce
Post by greig on Sept 11, 2021 8:35:22 GMT -5
Another thought is search for another used machine. Usually, you have to set up notifications because a fairly priced tumbler gets snapped up quickly.
JR8675309
Post by JR8675309 on Sept 12, 2021 6:39:07 GMT -5
I think covid drove purchases higher and manufacturing lower. Try Minn Lap Supp maybe? You have to email for info and then call to order FYI.
thestripedone
Post by thestripedone on Sept 21, 2021 12:17:20 GMT -5
Greig, thanks for referring me to Minn Lap Mfg. they had the motor at a good price, I ordered it and got it in 3 days. They are great people. The owner Val contacted me directly. I would highly recommend them. They will be my "go to" first, for purchases. It must be getting cold up there... btw I live in Florida. take care and be safe, Bruce
Post by rockpickerforever on Sept 21, 2021 12:29:49 GMT -5
I decided to just replace parts...I've looked all over for a motor. everyplace I look is "out of stock" even kingsley North. what gives with that? Is Lortone not making them any more for the 33 machines I wonder? any suggestions? thanks, Bruce Many have had to make this decision about their older cars. Fix it, or replace it? Because I love the Lortone machines, I would say to fix it if at all possible, or keep looking for a used one to turn up. Online, Swap meets, garage sales, rock shows, Lapidary clubs, estate sales, Craigslist (ugh). Just keep looking, and tell everyone you know you are looking. Wishing you luck in your search. I am on the fence about my older HP printer. The print head failed, a new one if it could be found is ~$200. A part of me says, replace that one part, but then what will go bad next? Another voice says, But you love that printer!! Living without it for now.......
thestripedone
Post by thestripedone on Apr 8, 2022 16:10:17 GMT -5
hi all, another problem with my lortone 33b tumbler the Idler shaft (the longer one I hope) is moving a little in and out and taking the pully with it knocking the belt off. I cant seem to move the pully closet to the Bering. maybe I did something wrong after I installed the motor with new berings and belts on the existing shafts. I hope this makes sense. I'm perplexed...I don't think I can post a video to show you all. help, thanks Bruce
dshanpnw
Member since December 2020
Post by dshanpnw on Apr 9, 2022 12:45:05 GMT -5
Hello thestripedone, I'm not sure what the problem could be. A video would be a great help. Be sure the pulleys are tight and aligned, and belt has tension on it. There are a few videos about 33B maintenance on YouTube that might help out, but sounds like you have the basics of it. BTW, I think the Lortone 33B is definitely worth repairing and using, especially since they are much harder to come by these days. It'll probably sell easily if you ever have to. Thanks for posting your problems, I hope you get it working properly.
Doug
thestripedone
Post by thestripedone on Apr 9, 2022 13:32:55 GMT -5
thanks Doug, do you know how I can post a video?
