Post by perkins17 on Oct 13, 2021 21:22:27 GMT -5
First off, let me say I am a VERY low budget cabber and need some advice on what oxide to use as a polish. I am thinking to get belts up to 1200 and then get a canvas or cork belt and charge it with cerium or ao. What polish do you guys use? I'm assuming AO cod get a pretty good shine but really don't know. At this time I can't afford diamond belts so this is pretty much my only idea. I have also heard of using diamond paste from a syringe. Is that easy to work with? I'm pretty sure my local rock shop sells that. Thanks in advance for the advice.
stonemon
Member since January 2017
Post by stonemon on Oct 13, 2021 22:05:13 GMT -5
I use 50,000 grit diamond paste from a syringe and get excellent results on a canvas wheel. Might have to watch your prep with obsidian and some other edgy materials but with the hard stuff it works great.
Post by perkins17 on Oct 13, 2021 22:17:46 GMT -5
I use 50,000 grit diamond paste from a syringe and get excellent results on a canvas wheel. Might have to watch your prep with obsidian and some other edgy materials but with the hard stuff it works great. Thanks!
Post by stardiamond on Oct 13, 2021 23:55:36 GMT -5
I was polishing everything with 100k diamond paste on a canvas pad. Recently, I was polishing some super 7 cabs and the shine wasn't very good. I had a leather pad on my 8 inch machine with tin oxide on it. I haven't used tin oxide for a very long time. I wet the pad with water and used the tin oxide that was already on it and it did a great job.
Post by perkins17 on Oct 14, 2021 9:11:44 GMT -5
I was polishing everything with 100k diamond paste on a canvas pad. Recently, I was polishing some super 7 cabs and the shine wasn't very good. I had a leather pad on my 8 inch machine with tin oxide on it. I haven't used tin oxide for a very long time. I wet the pad with water and used the tin oxide that was already on it and it did a great job. Ok thanks!
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Oct 14, 2021 9:17:20 GMT -5
1200 to final polish is a big jump. You'll probably want to add a 3000 step for sure. Maybe even a 14,000 if you still aren't happy with the shine.
Tin is a good all-around oxide, but white (optical-grade) Cerium is what we use for most things.
I use Aluminum Oxide for harder stones. You will sometimes still see the AlOx sold as "sapphire powder". It is 9 on the Mohs scale.
Post by perkins17 on Oct 14, 2021 9:51:35 GMT -5
Sorry total noob question, but where would I get a 3000 belt? Kingsley doesn't sell them except for in diamond.
Post by hummingbirdstones on Oct 14, 2021 9:56:36 GMT -5
Sorry total noob question, but where would I get a 3000 belt? Kingsley doesn't sell them except for in diamond. I think you can use a well worn and loaded 1200 and it will do the same as 3000.
Post by perkins17 on Oct 14, 2021 9:58:20 GMT -5
Sorry total noob question, but where would I get a 3000 belt? Kingsley doesn't sell them except for in diamond. I think you can use a well worn and loaded 1200 and it will do the same as 3000. Ok I will try that. Thank you for the helpful advice!
QuailRiver
Post by QuailRiver on Oct 14, 2021 20:14:16 GMT -5
For cabbing high silica content stones like quartz, agate, jasper, opal, etc., I use cerium oxide slurry on damped hard felt. For cabbing most of the softer stones like turquoise, chrysocolla, malachite, howlite, tigeriron, etc., I use *aluminum oxide slurry on slightly dampened suede leather.
Linde "A", Linde "B", Raybrite, and Sapphire Powder are all forms of aluminum oxide.
Post by perkins17 on Oct 14, 2021 21:17:38 GMT -5
For cabbing high silica content stones like quartz, agate, jasper, opal, etc., I use cerium oxide slurry on damped hard felt. For cabbing most of the softer stones like turquoise, chrysocolla, malachite, howlite, tigeriron, etc., I use *aluminum oxide slurry on slightly dampened suede leather. Linde "A", Linde "B", Raybrite, and Sapphire Powder are all forms of aluminum oxide. Ok. I might try AO if I don't get good results on a 1200. Thank you for advice.
Post by holajonathan on Oct 14, 2021 22:23:03 GMT -5
Sub-micron aluminum oxide works great on almost everything and the price is right. I got some from Kingsley North. $12 for one pound and it will last you a very long time.
Post by perkins17 on Oct 14, 2021 22:30:28 GMT -5
Sub-micron aluminum oxide works great on almost everything and the price is right. I got some from Kingsley North. $12 for one pound and it will last you a very long time. Ok thank you! I'm glad to know there is another option than $100,000, (slight exaggeration)a pound optical grade cerium.
Post by holajonathan on Oct 14, 2021 23:54:12 GMT -5
Post by perkins17 on Oct 15, 2021 9:07:45 GMT -5
Ok thanks! I could probably afford that. You get great results.
Post by holajonathan on Oct 15, 2021 10:44:12 GMT -5
