heathervee
Member since August 2021
Post by heathervee on Oct 16, 2021 7:19:58 GMT -5
Just bought off FB marketplace for $30. Have only used rotary. Any suggestions?
Post by knave on Oct 16, 2021 7:53:22 GMT -5
Just bought off FB marketplace for $30. Have only used rotary. Any suggestions? Awesome find! Youre gonna love it. 1 day in a vibe is like 1 week in a rotary. Once the stone is the shape you like and free of pits, the thumblers will get it polished in a week
heathervee
Post by heathervee on Oct 16, 2021 7:55:19 GMT -5
Is it OK for all kinds of rocks?
lordsorril
Member since April 2020
Post by lordsorril on Oct 16, 2021 11:49:56 GMT -5
Just bought off FB marketplace for $30. Have only used rotary. Any suggestions? Make sure you have the Industrial model UV-18, if not, it won't last long working on rocks.
Post by perkins17 on Oct 16, 2021 15:22:57 GMT -5
Just bought off FB marketplace for $30. Have only used rotary. Any suggestions? Make sure you have the Industrial model UV-18, if not, it won't last long working on rocks. Agreed. If it has a yellow stripe bowl, it's non-industrial. If it is blue, you're good. If it is yellow, you can use it for brass shell casings. 30 bucks is a steal.
heathervee
Post by heathervee on Oct 16, 2021 17:55:05 GMT -5
Make sure you have the Industrial model UV-18, if not, it won't last long working on rocks. Agreed. If it has a yellow stripe bowl, it's non-industrial. If it is blue, you're good. If it is yellow, you can use it for brass shell casings. 30 bucks is a steal. Blue stripe bowl for the win!!!!!!
Post by perkins17 on Oct 16, 2021 19:12:51 GMT -5
Agreed. If it has a yellow stripe bowl, it's non-industrial. If it is blue, you're good. If it is yellow, you can use it for brass shell casings. 30 bucks is a steal. Blue stripe bowl for the win!!!!!! Congrats! I think that's around 400 bucks brand new! You got a steal.
heathervee
Post by heathervee on Oct 17, 2021 15:09:52 GMT -5
Omg the bowl is huge!!!! Does it need to be 3/4 full like the rotary?
heathervee
Post by heathervee on Oct 17, 2021 15:13:33 GMT -5
Also it was used by a jewelery artiat for cleaning her work. Is there a special way that I need to clean it to get any chemicals that she might have used out of the bowl
Post by perkins17 on Oct 17, 2021 16:58:27 GMT -5
Also it was used by a jewelery artiat for cleaning her work. Is there a special way that I need to clean it to get any chemicals that she might have used out of the bowl Hello, you may want to visit tru-square metal products' web site. Also visit rock tumbler.com's section on vibratory tumbling. You may want a bowl for polish only. As far as cleaning, you should be fine if you start with 220.
Post by victor1941 on Oct 17, 2021 17:04:58 GMT -5
Heathervee, like Knave said this vibe is great for polishing but not for shaping unless you have soft material. You must use filler as indicated with media or other material to get good action. I doubt that any chemicals would remain in the polyethylene bowl that would damage most material. Several RTH members have this vibe and am sure they will give advice when it is needed.
Post by knave on Oct 17, 2021 17:48:29 GMT -5
Correct the UV18 is ALOT of of tumbler!! Maybe use aquarium gravel or pea gravel as filler.
terryjh
Member since July 2021
Post by terryjh on Oct 17, 2021 18:20:34 GMT -5
Heathervee, you asked about the fill volume. I have the smaller Thumler UV-10 model and fill it up to the very top of the interior center cone. I use ceramic media and pea gravel for a filler. I suspect the method for your bigger 18 is the same. Terry
heathervee
Post by heathervee on Oct 17, 2021 19:15:16 GMT -5
Thank you everyone! I have some ceramic media but there's no way I have enough to fill it yet! My husband is rewiring it as we speak and I'm excited to get a load in for polishing and test it out!
Post by knave on Oct 17, 2021 20:03:18 GMT -5
heathervee
Post by heathervee on Oct 18, 2021 8:42:53 GMT -5
More dumb questions... If I'm going to use media other than ceramic designed for tumbling, what do I need to look out for to make sure it's high enough quality for the vibe and not too hard to run with the rocks I'm polishing? Do I need to run gravel thru the rotary to knock it down like I do ceramic? Will colored aquarium gravel bleed and stain the rocks I'm tumbling?
Post by knave on Oct 18, 2021 8:47:01 GMT -5
If it’s polished you won’t need to prep them but if rough, definitely run them in 220 in the vibe for a day. Hardness. Ceramic is very hard. So harder is better in the vibe. The softer material mucks up the 220 stage fast enough.
Post by knave on Oct 18, 2021 8:47:44 GMT -5
Stay away from anything wax coated or color treated unless you know how it’s processed
heathervee
Post by heathervee on Oct 18, 2021 8:56:47 GMT -5
knave. So I use the rotary for stage 1 only, then everything else can be done in the vibe? I have to go and check out some more areas of the forum and YouTube, bc I thought we've been talking about the last stage polish in the vibe and now I'm getting myself a little turned around. Also I need more coffee...
Post by knave on Oct 18, 2021 9:00:12 GMT -5
knave. So I use the rotary for stage 1 only, then everything else can be done in the vibe? I have to go and check out some more areas of the forum and YouTube, bc I thought we've been talking about the last stage polish in the vibe and now I'm getting myself a little turned around. Also I need more coffee... Disclosure I have a loto and it’s all the vibe that I need. Yes stage 1 is all I will use a rotary for anymore. UV18 is a beast!!
