dkurtz
Tumbling to de-stress from my work. :)
Post by dkurtz on Oct 27, 2021 19:18:27 GMT -5
I brought a Diamond Pacific 50-T last fall and I have had both 25T barrel fail in this past month, on ly a year old. They both failed with the “roller” is bolted onto the both of the barrel. I was wondering if anyone had any thoughts if they could be saved, Some ideas: 1. Put a layer on around 1/2 “ of epoxy in the bottom of the inside 2. Put a lid gasket between the bottom and the bolt on “roller”. 3. Any other thoughts? Maybe I should even add a lid gasket on the bottom of my new barrels which should be on the way. jamesp I value your input on this. I wish I could make the barrels which you are now making, but don’t think I can, for another big tumbler. David
Post by jamesp on Oct 28, 2021 4:06:31 GMT -5
Wish I could help David. I have no experience with those hex barrels. Covington makes a similar 40 pound barrel.
mudmaker
Member since March 2022
Post by mudmaker on Mar 2, 2022 20:55:47 GMT -5
HI, I Just joined this after I saw your post. I have the same problem and I am wondering if you have found any solution to patching the bottom. I will try the rubber gasket idea if I can find some material. I am also trying to source some rubber to use for this. I have 3 25 lb barrels that will wear out but my 65 lb barrel has already and if the rubber works I might as well make my own gaskets. Thanks for any ideas!
Post by catmandewe on Mar 2, 2022 21:51:40 GMT -5
I make new gaskets out of the shower liner you can buy in the tile section at Home Depot, it comes in 6 foot widths and can make quite a few gaskets, set it on a piece of plywood and lay the lid on the liner, mark it out and punch the bolt holes out with an empty 223 round.
Tony
jimmie
Member since August 2021
Post by jimmie on Mar 3, 2022 7:24:45 GMT -5
Good advice Tony. I’m doing a tile job right now, the pvc liner is tough. You can also use edpm roofing, rubber roofing. Both are very durable.
mudmaker
Post by mudmaker on Mar 3, 2022 13:51:40 GMT -5
I was able to to stop the leaking with a temporary rubber gasket so I will try making my own gaskets and think it may be easiest for me to just order a similar type of neoprene rubber sheet if available. Does anyone know what the rubber is that comes with the diamond pacific barrels? Also, has anyone tried to fill or glue a patch to the inside of these types of barrels to keep the plastic from getting a hole in the first place?
jimmie
Post by jimmie on Mar 3, 2022 14:15:13 GMT -5
Edpm is a thick rubber roofing, it’s held down with contact cement. It would probably work
