manodepiedra
Rhodochrosite Argentine National Stone
Member since November 2021
Post by manodepiedra on Nov 2, 2021 9:47:14 GMT -5
Hello tumbadores friends, I am new to the forum, I live in San Juan - Argentina and I am starting with the tumbling of stones, especially on Rhodochrosite (mosh 4.5) since I have access to a significant amount and ease of obtaining this very valuable rock for our country Argentina since here it is considered a very important "national stone". I wonder if someone can guide me through links or tips to achieve the polishing (final stage) of this soft semi-precious rock, since I cannot polish it, the last stage fails me with aluminum oxide (ALMATIS P10 feinst) and I can't understand what is wrong. I use a rolling machine with 23 kg of stone (this represents 3/4 of its total capacity), without plastic pellets or ceramic cylinders, only rhodochrosite rock of various sizes ranging from 5 mm to 40 mm. I usually flip for hours, not days, checking every so often to see results but my rock doesn't polish, sometimes it even gets hit. Aluminum oxide (proportion): 1 level tablespoon for every 450 grams of stone. Thank you in advance for your comments. All is welcome friends
Post by hummingbirdstones on Nov 2, 2021 10:00:21 GMT -5
Welcome from Northern Arizona!
I don't tumble, but others will come along to help you out.
manodepiedra
Post by manodepiedra on Nov 2, 2021 10:36:14 GMT -5
Thanks friend 😀
Post by parfive on Nov 2, 2021 23:54:57 GMT -5
Welcome aboard.
Trying to polish fifty pounds of soft rock all in one shot is likely part of your problem.
Can you fit a smaller barrel on your machine?
Post by parfive on Nov 3, 2021 0:01:36 GMT -5
Bienvenido a bordo. Tratar de pulir cincuenta libras de roca blanda todo de una sola vez es probablemente parte de su problema. ¿Puedes colocar un barril más pequeño en tu máquina? [Maybe that worked . . . and maybe it didn't.]
Post by rockjunquie on Nov 3, 2021 7:15:26 GMT -5
Welcome from Virginia. Rhodochrosite is such a beautiful stone.
Post by Peruano on Nov 3, 2021 9:02:58 GMT -5
Bienvenido de Nuevo Mexico.
Post by Rockoonz on Nov 3, 2021 10:51:37 GMT -5
Welcome from Arizona.
Post by As I in does tries! on Nov 3, 2021 15:25:55 GMT -5
English: Use Cerium Oxide for best results, Aluminum Oxide is not the best polish for polishing Rhodochrosite!
Español: Utilice óxido de cerio para obtener los mejores resultados, ¡el óxido de aluminio no es el mejor pulidor para pulir la rodocrosita!
manodepiedra
Post by manodepiedra on Nov 10, 2021 12:24:50 GMT -5
Bienvenido a bordo. Tratar de pulir cincuenta libras de roca blanda de una sola vez es probablemente parte de su problema. ¿Puede colocar un barril más pequeño en su máquina? Gracias parfive, sospechaba que era un montón de 50 libras de roca, tengo un barril más pequeño de 30/35 libras que venía con la máquina de laminación, puedo usar eso usando bolitas de plástico (tienen medidas de 3 mm) para evitar que la roca se pegar. Algún otro consejo válido para conseguir un buen pulido.
manodepiedra
Post by manodepiedra on Nov 10, 2021 12:30:27 GMT -5
Español: Utilice óxido de cerio para obtener los mejores resultados, ¡el óxido de aluminio no es el mejor pulidor para pulir la rodocrosita! Español: Utilice óxido de cerio para obtener los mejores resultados, ¡el óxido de aluminio no es el mejor pulidor para pulir la rodocrosita! Muchas gracias por el consejo, voy a utilizar óxido de cerio en lugar de óxido de aluminio. ¿Puede decirme una proporción correcta de óxido de cerio para una cierta cantidad de roca? ¿También utilizo bolitas de plástico o solo roca con óxido de cerio? ¿Cuánto tiempo recomiendas girar el vaso de piedra? Todos los consejos son bienvenidos, estoy muy perdido en el tema final del pulido, las otras etapas van bien pero no puedo pulir la rodocrosita
