mjones
Member since November 2021
Post by mjones on Nov 6, 2021 4:10:38 GMT -5
I recently purchased a secondhand Lortone 33b tumbler. After just a few days use the rollers that drive the barrels are wearing badly and the barrels roll around all over the place or stall against the sides. I guess I can buy a new set of rollers but can anyone give me a clue as to why these have worn so badly? I don’t think the barrels were overloaded, they were about half full of mixed size rocks and the appropriate grit with enough water to just cover the rocks. I lubricated the bearings and everything was turning freely when I started. It is unusable at present.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Nov 6, 2021 9:20:02 GMT -5
What do you mean when you say the rollers are "worn out". Are they straight Is the rubber coating coming off Are the bearings getting thin
New Rollers are $8 at rockshed
mjones
Post by mjones on Nov 7, 2021 4:32:06 GMT -5
New Rollers are $8 at rockshed Thanks for the response. The rollers were in good condition, after a few days of tumbling the rollers are now worn unevenly and the metal is showing through in places. Is it possible post a picture in this forum?
quartzilla
Member since April 2020
Post by quartzilla on Nov 7, 2021 4:40:21 GMT -5
Sounds like maybe someone had put that Plasti-dip material on the rollers to make them look new. I had some rollers that were the same and the barrels didn’t want to turn good. I tried the Plasti-Dip which worked great, the rollers grabbed the barrels better and everything was rolling great….for about 2 days when all the Plasti-Dip wore off. Get new rollers from the Rock Shed and you should be back in business.
