Post by holajonathan on Nov 8, 2021 1:01:16 GMT -5
Post by rockjunquie on Nov 8, 2021 7:24:28 GMT -5
Cool! Not sure which I like best, but the first looks pretty darn good.
Brian
Member since July 2020
Post by Brian on Nov 8, 2021 9:19:24 GMT -5
I agree with Tela. It’s hard to pick out a favorite when you were able to pull out so many cool patterns in those slabs. The contrast of patterns and the framing of the chaos in the middle of first one is great, but the third picture really has some cool depth as you sliced through the different levels.
Post by hummingbirdstones on Nov 8, 2021 9:41:26 GMT -5
Awesome slabs!
Many times Vince will slice in different directions, especially on larger pieces, so we can decide which direction has the best pattern for a piece of rough. On pieces like this, it's a win-win no matter which way you slice it.
Post by holajonathan on Nov 8, 2021 11:17:06 GMT -5
Cool! Not sure which I like best, but the first looks pretty darn good. It was a pretty large rock, shaped about like a 3" thick book. I already had a bunch of slabs that look almost identical to the first photo, so I started cutting in other directions. Cabbing slabs like those in the second photo are fun because of how the pattern changes when grinding the dome. I agree with Tela. It’s hard to pick out a favorite when you were able to pull out so many cool patterns in those slabs. The contrast of patterns and the framing of the chaos in the middle of first one is great, but the third picture really has some cool depth as you sliced through the different levels. Cutting through wavy layers (2nd and 3rd photos) is is almost always my favorite, whether the rock is crazy lace, a Montana agate, or just about anything else with layers, bands, or waves. I even like doing it with plume agates, which turns well defined plumes (like some Graveyard Point plume agate) into something like snowflakes. Awesome slabs!
Many times Vince will slice in different directions, especially on larger pieces, so we can decide which direction has the best pattern for a piece of rough. On pieces like this, it's a win-win no matter which way you slice it. When I have big rough I usually cut at least a few big slabs on my bigger saws. Cutting big slabs is efficient, but I think big slabs are overrated for cabbing. If it is a good large slab, I have to either mark out a ton of preforms and spend an hour on a trim saw cutting them all out, or I just mark out a few preforms and end up wasting a bunch of material. Once I'm bored cutting big slabs, if the rock is ok but not great, I just toss it aside. But If I really like the rock, I block up the rest into pieces with around a 3" x 4" cross section. That is the perfect cut for my 10" slab saw with a thin (0.04") kerf MK Diamond 303 blade. I get very smooth flat cuts with the 10" MK303 blade when cutting these blocks since there is no blade deflection. That's how all of the slabs in this thread were cut. They are all cut around 0.24" thick, which means for every 6 cuts, I am only losing the equivalent of one slab to the blade.
CLErocks
Member since October 2021
Post by CLErocks on Nov 8, 2021 16:16:46 GMT -5
Very interesting, both visually and the information/reasons for doing such a thing. My brain hasn't gotten this far down the rabbit hole yet. 😂😂😂
Post by jasoninsd on Nov 8, 2021 19:14:57 GMT -5
Thanks for showing the two different cuts! I've been doing this with most of my Mexican Lace rough.
You bring up a good point with regards to large slabs. I have a tendency to try and avoid cutting large slabs. I prefer the smaller slabettes for most of my rough because I agree with the amount of waste when it comes to the larger slabs...
Post by holajonathan on Nov 12, 2021 2:34:08 GMT -5
Started a couple today
Post by miket on Nov 12, 2021 10:40:44 GMT -5
Post by jasoninsd on Nov 12, 2021 20:18:10 GMT -5
Started a couple today I love the patterns you chose for these...and they're ovals!
Post by holajonathan on Nov 12, 2021 20:56:40 GMT -5
Started a couple today I love the patterns you chose for these...and they're ovals! I'm learning to love the smallish oval (maybe 30mm x 20mm?). It takes 1/4 as long from start to finish as my normal, huge cabs. I know it's not a race, but I have a lot of slabs that I like, but don't love, and I can't see spending all day creating a couple cabs of that material.
Post by hummingbirdstones on Nov 12, 2021 21:06:15 GMT -5
I love the muted color tones in these cabs!
Post by holajonathan on Nov 12, 2021 21:08:43 GMT -5
I love the muted color tones in these cabs! Me too. With crazy lace, I prefer good patterns over in-your-face colors (if I have to choose). A little color is nice, but it's the geometric shapes and lacy patterns that I like most.
Post by jasoninsd on Nov 13, 2021 0:25:31 GMT -5
I love the patterns you chose for these...and they're ovals! I'm learning to love the smallish oval (maybe 30mm x 20mm?). It takes 1/4 as long from start to finish as my normal, huge cabs. I know it's not a race, but I have a lot of slabs that I like, but don't love, and I can't see spending all day creating a couple cabs of that material. This is what I've been fighting with lately. I have a really difficult time with "waste"...so I always want to use every square inch of every single slab of every single rock that I cut. However, I'm coming to the realization that there won't be enough time to work every inch of every piece...so I need to be more picky and worry less about the "waste". I also agree with what you and Robin were saying about the muted colors in the Mexican Lace. I was initially all about the loud colors and "crazy" fortification patterns, but I'm really starting to have a better appreciation for some of the more subtle beauty that can come out of these.
Post by holajonathan on Nov 13, 2021 0:50:08 GMT -5
jasoninsdLiberate yourself, Jason. You've got enough slabs and preforms. Just cab the ones you love. It sure makes the process a lot more fun. And making so-so cabs is sort of frustrating. Here are a few slabs I marked out last night. They are all pretty big slabs, but in each case, I only saw one preform that demanded to be cut. I probably could have marked out 4 or 5 cabs per slabs, but I've got hundreds of slabs, so I don't see the point. I might end up marking out a few other little ones, but I'm going to cut out the one preform that I really want to cab, and to hell with the rest of the slab!
Post by holajonathan on Nov 13, 2021 0:54:34 GMT -5
Guess why I am cutting this one...
All that sparkle with fluorescent tube lights. In better light, the sparkle... it's too much.
Post by jasoninsd on Nov 13, 2021 1:01:56 GMT -5
jasoninsd Liberate yourself, Jason. You've got enough slabs and preforms. Just cab the ones you love. It sure makes the process a lot more fun. And making so-so cabs is sort of frustrating. Here are a few slabs I marked out last night. They are all pretty big slabs, but in each case, I only saw one preform that demanded to be cut. I probably could have marked out 4 or 5 cabs per slabs, but I've got hundreds of slabs, so I don't see the point. I might end up marking out a few other little ones, but I'm going to cut out the one preform that I really want to cab, and to hell with the rest of the slab! Yeah...see I'm staring at these and I'm seeing the "other" 3-4 potential cabs! LOL - Maybe you should just put a LFRB over in the corner of the work area and toss the "unused" sections of those slabs into it. Once it's full, you could just send it to me since it's just "waste"! LOL Seriously though, you really could sell the "leftovers" for a decent price on eBay (or here) and definitely have a nice chunk towards even more material. I do get what you're saying about not using every square inch...but I do see some other potentials in those slabs. On the other hand, you're looking at them up close and are maybe seeing problem areas I'm not...
Post by jasoninsd on Nov 13, 2021 1:03:22 GMT -5
Guess why I am cutting this one... All that sparkle with fluorescent tube lights. In better light, the sparkle... it's too much. That one is a great specimen for the "you know what"!
Post by holajonathan on Nov 13, 2021 1:12:07 GMT -5
jasoninsd Liberate yourself, Jason. You've got enough slabs and preforms. Just cab the ones you love. It sure makes the process a lot more fun. And making so-so cabs is sort of frustrating. Here are a few slabs I marked out last night. They are all pretty big slabs, but in each case, I only saw one preform that demanded to be cut. I probably could have marked out 4 or 5 cabs per slabs, but I've got hundreds of slabs, so I don't see the point. I might end up marking out a few other little ones, but I'm going to cut out the one preform that I really want to cab, and to hell with the rest of the slab! Yeah...see I'm staring at these and I'm seeing the "other" 3-4 potential cabs! LOL - Maybe you should just put a LFRB over in the corner of the work area and toss the "unused" sections of those slabs into it. Once it's full, you could just send it to me since it's just "waste"! LOL Seriously though, you really could sell the "leftovers" for a decent price on eBay (or here) and definitely have a nice chunk towards even more material. I do get what you're saying about not using every square inch...but I do see some other potentials in those slabs. On the other hand, you're looking at them up close and are maybe seeing problem areas I'm not... Yeah, they've got fractures or other problem spots. A lot of the fractures look pretty solid, but seeing as I've got enough slabs to mark out 1000+ preforms without fractures, I don't see any point in making fractured cabs unless there is something so amazing about it that I can't resist.
Post by holajonathan on Nov 13, 2021 1:14:14 GMT -5
Guess why I am cutting this one... All that sparkle with fluorescent tube lights. In better light, the sparkle... it's too much. That one is a great specimen for the "you know what"! Sure is. It's got more sparkle than a drag queen. Or so I've been told. I mean, it's not like.... you know what I mean.
