electrocutus
Member since October 2020
Post by electrocutus on Nov 11, 2021 15:13:56 GMT -5
Here comes a stupid queston I am sure experienced tumblers know the answer to.
I was cleaning a batch of rocks this morning, and I suddenly thought: If grit can grind down and shape hard rocks in a matter of weeks, how come it doesn't eat away the inside of a rubber barrel at the same rate? I would think that soft rubber would not hold up to Silicon Carbide grit, but yet it does. Why is that?
Post by mohs on Nov 11, 2021 15:52:36 GMT -5
well its got something to do w/ molecular structure which is something I certainly can't explain
suffice to say those sharpy little grits bounce around tumbling like rocks in a barrel
pf course, they think its fun butte I never asked one mohstly
hope your day is to!
Post by knave on Nov 11, 2021 15:53:44 GMT -5
It’s a great question! One way I think of it…. Scale it up. If you drive over a piece of quartz with your car, the tire will give way to the rock and then be resilient and bounce back. As long as it is kept cool rubber is extremely tough and resilient, and very difficult to separate the molecules.
Post by knave on Nov 11, 2021 15:55:00 GMT -5
Also a Mohs 6 hammer can shatter a Mohs 10 diamond How does that work??
Post by parfive on Nov 11, 2021 15:55:08 GMT -5
Same deal w/the tires on your car.
Post by mohs on Nov 11, 2021 16:04:20 GMT -5
ricochet grits that happening
electrocutus
Post by electrocutus on Nov 11, 2021 16:16:19 GMT -5
Same deal w/the tires on your car. Yes, kind of, but I think that if I started rubbing rocks and grit on the side of my tire something bad would eventually happen :-) :-(
