Post by fernwood on Nov 15, 2021 12:20:08 GMT -5
Does anyone else end up doing this?
I currently have some Wisconsin Moonstone that has been in 120/220 for 3 weeks. Why? Because time, weather, etc., has not allowed me to do a clean out. Have some other hard rocks that have been going for 6 weeks in 60/90 due to same.
I usually do not worry about extended tumbles after stage 1. Some hard rocks I let go in stage 1 for months.
Have you ever had some major things happen after a lengthy tumble in any stages? So far I haver been lucky.
I normally do 60/90, 120/220, 400/600, 1200, and 12,000 in a rotary.
reeniebeany
Rotary Only
Member since January 2020
Post by reeniebeany on Nov 15, 2021 14:47:22 GMT -5
For the same reasons, I have also left things tumbling for extended periods. Not had any problems yet, but I am pretty new to this, and mostly do cheap, local rocks. Nothing fancy.
Post by Rockindad on Nov 15, 2021 17:05:53 GMT -5
Does anyone else end up doing this? I currently have some Wisconsin Moonstone that has been in 120/220 for 3 weeks. Why? Because time, weather, etc., has not allowed me to do a clean out. Have some other hard rocks that have been going for 6 weeks in 60/90 due to same. I usually do not worry about extended tumbles after stage 1. Some hard rocks I let go in stage 1 for months. Have you ever had some major things happen after a lengthy tumble in any stages? So far I haver been lucky. I normally do 60/90, 120/220, 400/600, 1200, and 12,000 in a rotary. Not that long ago I wasn't feeling well for an extended period of time and was always tired and physically weak. While we did not stop tumbling, and A.J. kept things going, there were times when some of our barrels would run anywhere from 3-5 weeks before being cleaned out. The only thing bad that happened was that it was a far from efficient grind and the slurry was usually a thick pudding but other things were a priority then. Would not recommend this for any fragile materials though.
Post by perkins17 on Nov 15, 2021 19:19:50 GMT -5
I have done this due to cold weather and have had no adverse affects. I have left 500 AO going for "too long" (in my book, there isn't such thing) and had the stones get a pretty satisfactory polish. I will run them through 14k for a better shine though.
Benathema
Member since November 2019
Post by Benathema on Nov 16, 2021 16:16:38 GMT -5
The only time I've had an issue is with fresh sharp material in coarse, where the entire load is new. The space available in the tumbler increased so much that the rocks were doing more smashing than grinding. It left a lot of them bruised pretty bad. Nothing another coarse run with a proper fill level couldn't fix. Another issue with coarse is if the slurry forms a paste that glues the rocks to the walls, leaving a donut hole in the middle with rocks banging around. So my issues with extended runs only seem to be with coarse, not later stages.
Post by Bob on Nov 22, 2021 20:48:56 GMT -5
The only time I've had an issue is with fresh sharp material in coarse, where the entire load is new. The space available in the tumbler increased so much that the rocks were doing more smashing than grinding. It left a lot of them bruised pretty bad. Nothing another coarse run with a proper fill level couldn't fix. Another issue with coarse is if the slurry forms a paste that glues the rocks to the walls, leaving a donut hole in the middle with rocks banging around. So my issues with extended runs only seem to be with coarse, not later stages. My experience exactly.
Post by Bob on Nov 29, 2021 19:54:24 GMT -5
...Nothing another coarse run with a proper fill level couldn't fix... One of the best things ever written in this forum! That is what it's all about and how to get quality results.
