ivan
Member since March 2014
Post by ivan on Dec 11, 2021 23:37:37 GMT -5
Is there anybody here on our rocktumblinghobby family that sells or can direct this SC to where I can compare pricing & buy Vibra-Dry compounds for Vibratory tumblers? Any information would be appreciated. Thank you very much! IV
Post by hummingbirdstones on Dec 12, 2021 10:12:52 GMT -5
Vibra Dry is made by Diamond Pacific. I don't tumble, but I would guess that Kingsley North and The Rock Shed both also carry similar products.
ivan
Post by ivan on Dec 12, 2021 22:57:53 GMT -5
Vibra Dry is made by Diamond Pacific. I don't tumble, but I would guess that Kingsley North and The Rock Shed both also carry similar products. Will/should give Don, I believe his name is at Diamond Pacific a call? Have Edward E. Smith book on How to Tumble Polish Rocks into Gems. It states that Mr. Smith was the inventor of the Vibra-Dry Compounds, Viking-Vibra-Sonic, and the Mini-Sonic Tumblers.
His Book, Tumblers & Compounds I'm just trying to get familiar with? He lists what he called a Wet'nDry "Deep Luster" compound and a brief description of the material that he developed. Not sure, if our Forum Family has ever used it or if it is on the market?
With that said ... I decided will have to go with the Original Vibra-Dry polishing compound that is still available through Diamond Pacific as you mentioned. Perhaps at some time there may be somebody here that has used the Vibra-Dry and can enlighten me a bit?
Thanks for taking the time to reply. IV USAF 62-66
Post by hummingbirdstones on Dec 13, 2021 9:31:07 GMT -5
I would call Don and talk to him. I have only used the 50K Vibra Dry in a Vibe that I use for jewelry polishing. I will throw finished cabs in there for a while even after getting a wet shine on them with the usual way. For some reason the 50K Vibra Dry really seems to make them pop even more.
ivan
Post by ivan on Dec 13, 2021 16:08:24 GMT -5
I would call Don and talk to him. I have only used the 50K Vibra Dry in a Vibe that I use for jewelry polishing. I will throw finished cabs in there for a while even after getting a wet shine on them with the usual way. For some reason the 50K Vibra Dry really seems to make them pop even more. Called & talked to Don ... Very knowledgeable & helpful. Appreciate the info you posted about what & how you use the Vibra-Dry. In the process of doing up some gemstone preforms. Using both the wet & experimenting with incorporating the dry procedure. Hoping to obtain the excellent results you've been able to do. Thanks again! IV
