bexter
Member since October 2021
Post by bexter on Dec 12, 2021 17:02:30 GMT -5
I bought a 8" Ameritool flat lap, used the first time in Oct. I have used it about 4-5 times. The first time I noted that there was water everywhere on the table, figured it was just a messy new tool - there was drainiage into the cup. Since then, drainage has gotten worse, but always eventually it would drain into the cup after filling up the plastic boot tray I have it sitting it. I falsely assumed is was leaking around the side drain.
Today - realized it is draining out of the bottom. ALL of it - none coming out the side drain. I clean it each time, rinse thoroughly until water runs clear and then rinse again, tip it on it's side to drain it, etc. I have pushed the hose in, pulled it out further, nothing seems to work. Before I disassemble, does anyone have any tips, tricks, is this normal?
Thanks in advance.
bexter
Post by bexter on Dec 12, 2021 18:08:37 GMT -5
After looking more closely at the Ameritool website, they show an exterior valve to be turned on/off. I have a piece of tubing sticking out. Off it disassemble to see if it was inserted backwards or what is going on with this piece.....
