darcyj76
Member since February 2021
Post by darcyj76 on Dec 18, 2021 12:11:31 GMT -5
I hope this link works!
Loud Lot-O, I place my hand with barely any pressure on the front of it and suddenly, quiet Lot-O!
Any thoughts?
jimmie
Member since August 2021
Post by jimmie on Dec 18, 2021 12:15:33 GMT -5
It’s a machine that vibrates, you stopped some of the vibration.
Post by perkins17 on Dec 18, 2021 12:17:50 GMT -5
It’s a machine that vibrates, you stopped some of the vibration. Yeah, I agree. Probably everything inside stopped shaking against the bowl.
darcyj76
Post by darcyj76 on Dec 18, 2021 12:33:52 GMT -5
Oh I feel dumb.
Oh my.
Um, thank you both, I’ll see myself out!
jimmie
Post by jimmie on Dec 18, 2021 12:44:20 GMT -5
Mostly everything I’ve learned has been from making mistakes.
brybry
Enter your message here...
Member since October 2021
Post by brybry on Dec 18, 2021 15:14:46 GMT -5
Oh I feel dumb. Oh my. Um, thank you both, I’ll see myself out! 😳 Don't feel dumb, we all have brain farts. Learning what your vibe sounds like as your going through the various stages is a good thing. I'm learning to tell when mine is gumming up by the sound. Only dumb question is the one not asked.
Post by Rockindad on Dec 18, 2021 15:26:00 GMT -5
I hope this link works! Loud Lot-O, I place my hand with barely any pressure on the front of it and suddenly, quiet Lot-O! Any thoughts? I've spent many hours studying the Lot-O, and yours does sound a bit off compared to what I am used to. May just be the angle of the filming, but your barrel seems pretty sunk into the frame, do you happen to push it into the frame at all? Ours sounds like yours does when you put your hand on it all of the time. Yours sounds like there is vibration that is not being transferred from the frame to the barrel. Just a guess- is the rubber nub on the bottom of the barrel in contact with the platform?
darcyj76
Post by darcyj76 on Dec 20, 2021 16:12:28 GMT -5
I haven’t been pushing it down all the way-I used to and learned that was bad, but maybe I am still pushing it in too far! I hope this link works! Loud Lot-O, I place my hand with barely any pressure on the front of it and suddenly, quiet Lot-O! Any thoughts? I've spent many hours studying the Lot-O, and yours does sound a bit off compared to what I am used to. May just be the angle of the filming, but your barrel seems pretty sunk into the frame, do you happen to push it into the frame at all? Ours sounds like yours does when you put your hand on it all of the time. Yours sounds like there is vibration that is not being transferred from the frame to the barrel. Just a guess- is the rubber nub on the bottom of the barrel in contact with the platform?
CLErocks
Post by CLErocks on Dec 20, 2021 17:45:41 GMT -5
Mine has a line around the top of the black barrel. I push mine in just so the line is showing. At a slight angle so the top is angled forward and the line mirrors the red frame.
So maybe look at that??
I’m new too…so if someone thinks that’s wrong, let me know. I just watched a bunch of other people videos before I used mine.
Post by Rockindad on Dec 20, 2021 19:45:46 GMT -5
I haven’t been pushing it down all the way-I used to and learned that was bad, but maybe I am still pushing it in too far! I've spent many hours studying the Lot-O, and yours does sound a bit off compared to what I am used to. May just be the angle of the filming, but your barrel seems pretty sunk into the frame, do you happen to push it into the frame at all? Ours sounds like yours does when you put your hand on it all of the time. Yours sounds like there is vibration that is not being transferred from the frame to the barrel. Just a guess- is the rubber nub on the bottom of the barrel in contact with the platform? For what it's worth- we do not push ours in at all. We actually have a 1 1/2" spacer under the barrel so it cannot sink in too far. After adjusting the dowel and doing this the machine runs perfectly. It never bogs down anymore, even when using a ridiculous amount of SiC grit and accumulating a lot of mud.
Post by perkins17 on Dec 20, 2021 19:51:47 GMT -5
Oh I feel dumb. Oh my. Um, thank you both, I’ll see myself out! 😳 Don't feel dumb! I've definitely been there 😂!
darcyj76
Post by darcyj76 on Dec 21, 2021 18:48:59 GMT -5
YOU WERE RIGHT!!! Thank you!!! I set it in without pushing it down at all, and it is making the normal sound! Thank you SO much!!! I haven’t been pushing it down all the way-I used to and learned that was bad, but maybe I am still pushing it in too far! For what it's worth- we do not push ours in at all. We actually have a 1 1/2" spacer under the barrel so it cannot sink in too far. After adjusting the dowel and doing this the machine runs perfectly. It never bogs down anymore, even when using a ridiculous amount of SiC grit and accumulating a lot of mud.
Post by Rockindad on Dec 21, 2021 19:04:17 GMT -5
YOU WERE RIGHT!!! Thank you!!! I set it in without pushing it down at all, and it is making the normal sound! Thank you SO much!!! For what it's worth- we do not push ours in at all. We actually have a 1 1/2" spacer under the barrel so it cannot sink in too far. After adjusting the dowel and doing this the machine runs perfectly. It never bogs down anymore, even when using a ridiculous amount of SiC grit and accumulating a lot of mud. No problem. My guess was only based on what I have heard with my own machine through all of my fiddling/experimenting.
