Post by parfive on Dec 26, 2021 14:23:18 GMT -5
Tommy So far, I've loaded five pics to Cloudinary. Any reason/explanation why they've duplicated each image? Doubles are all same size and resolution as original, just tagged differently. For instance, a pic first uploaded as TheScream is tagged TheScream_ygr1zd and there's also a double now tagged rtjs6mscgkmc29nf68m4.
Post by MsAli on Dec 26, 2021 21:42:08 GMT -5
Has this been recent for you? It didn't duplicate anything for when I used it the other day
Post by knave on Dec 26, 2021 22:12:23 GMT -5
It uploads when you click the button from this site. That’s likely the garbled numbers/letters version. If you manually uploaded a pic to cloudinary that’s the one that has the correct ish name.
Post by Tommy on Dec 28, 2021 14:32:23 GMT -5
testing...
Post by Tommy on Dec 28, 2021 14:36:32 GMT -5
Tommy So far, I've loaded five pics to Cloudinary. Any reason/explanation why they've duplicated each image? Doubles are all same size and resolution as original, just tagged differently. For instance, a pic first uploaded as TheScream is tagged TheScream_ygr1zd and there's also a double now tagged rtjs6mscgkmc29nf68m4. Assuming you are talking about it having two copies of the image stored on the Cloudinary website, I have no idea. I tried to recreate it on my side - using the "automatic backup" feature but still no.
rewdownunder
Member since March 2012
Post by rewdownunder on Dec 28, 2021 14:51:25 GMT -5
just checking an upload  Gold Tree on Chrysoprase by Desert Fire Designs Western Australia Tommy prior problem I reported is resolved Thanks
Post by parfive on Dec 28, 2021 15:40:57 GMT -5
Thanks, Tommy . Now I’m curious . . . I’ll have to dig into those posts/threads where I used the images and see which version ended up on RTH. If it’s consistently my original tagged pic, it should be safe to delete the gobbledygooked doubles.
Post by parfive on Dec 28, 2021 23:57:02 GMT -5
Well, not what I expected. All the pics that appear on the board are the doubles, not the originals I named and uploaded. Weird.
Fwiw, I uploaded another pic two days ago to use in a pm. Cloudinary Upload button was inactive so I just copied the url and used the old Insert Image button. That pic has not been duplicated back in the Cloud library.
So now I’m wondering if the drag and drop routine is somehow the culprit.
Post by knave on Dec 29, 2021 0:00:30 GMT -5
Well, not what I expected. All the pics that appear on the board are the doubles, not the originals I named and uploaded. Weird. Fwiw, I uploaded another pic two days ago to use in a pm. Cloudinary Upload button was inactive so I just copied the url and used the old Insert Image button. That pic has not been duplicated back in the Cloud library. So now I’m wondering if the drag and drop routine is somehow the culprit. Yes, when you drag and drop, it automatically uploads a gobbledegook file name to cloudinary server, and hot links it in your post all in one smooth motion.
Post by knave on Dec 29, 2021 0:01:11 GMT -5
It uploads when you click the button from this site. That’s likely the garbled numbers/letters version. If you manually uploaded a pic to cloudinary that’s the one that has the correct ish name. What I saided here.
