electrocutus
Member since October 2020
Post by electrocutus on Jan 25, 2022 14:44:05 GMT -5
I experimented a bit with using plastic pellets in my rotary tumbler for the polishing stage, and I have been wondering if they absorb some of the polish, requiring me to use more polish than I would normally use.
I think I'll stop using them anyway in favour of ceramic media, but since I still have some of it, I don't want it to go to waste.
I find that even if I use the plastic pellets only in the polish stage, the pellets come out grey. That's to be expected since the slurry is grey, but does that mean that a portion of the polish (AO) also gets in the pellets and there is less available to do the actual polishing? The last barrel I polished didn't come out as well as I expected, so I was wondering if it could be because of the pellets.
Thanks.
Post by tims on Jan 25, 2022 17:11:31 GMT -5
If your ceramic hasn't been all the way through polish it's going to be a bit coarse for polish stage and may give you more headaches than the plastics. I assume the plastics do hold a bit of your polish and mud (hence the color) but if they're only used for polish stage don't know how that would hurt anything, other than the plastic not giving a hard surface to grind against. The plastic should only hold stuff on imperfections on its surface, it won't absorb anything unless you're using foam or something porous.
Post by Bob on Feb 3, 2022 11:11:31 GMT -5
I've been using 3/8" ceramics for some years, though not in polish on purpose. The interior of them sometimes has internal cracks, which are hard to see. I guess it's quality control or difficulty in the making, not sure. But it has scared me away from trying them in polish. I've also tried 1-2mm spherical ceramics in polish and it was a big mess and also ruined the polish batch.
I use plastic beads available from Kingsley North. They are black and float. Most of them have been used in polish over and over for 5 years or so now and work great. Beads from other suppliers have not done well for me and some have driven me crazy they are so hard to deal with. I used to keep the beads for different polishes (alum ox, tin ox, cer ox, chrome ox) separate just in case, but I no longer do that and have noticed no bad effects as long as I rinse them well.
Post by perkins17 on Feb 3, 2022 11:41:09 GMT -5
I am in favor of ceramic media, not plastic. I found plastic to be hard to work with and believe it impedes grinding action. Ceramics can be used all the way through, like rocks. Hope that helps!
Post by greig on Feb 3, 2022 12:02:37 GMT -5
For sure the coarse grits penetrate some of the plastic beads. I don't think the polish penetrates. However, it might coat the beads in polish, just like it coats the rocks a little bit. I don't see that as an issue and wouldn't add more polish because of it. I have noticed that there is less coating of polish on beads and stones if I have too much water, but that makes the polish less effective. Still, I while like ceramic media better, both work.
Post by Bob on Feb 3, 2022 12:12:41 GMT -5
I am in favor of ceramic media, not plastic. I found plastic to be hard to work with and believe it impedes grinding action. Ceramics can be used all the way through, like rocks. Hope that helps! I found plastic beads inhibit grinding also on grits larger than 220.
hypodactylus
Member since July 2021
Post by hypodactylus on Feb 3, 2022 15:48:22 GMT -5
It is my understanding that grit (including polish) can become embedded in plastic media. I believe this is why people may recommend not mixing plastic media used in different stages. As for 'absorbing' enough to make any difference in how much polish you use; I don't honestly think it will make a big difference.
I personally despise using floating plastic pellets; they are a pain during cleanout stages and I don't like to keep that many separate stashes of media. I use the same ceramic media from stage 2 through polish. Occasionally I will use it in stage 1, but not usually. I keep a separate stash of ceramic media that has been through the polish stage, in case I need to add more to later stages.
I have used rubber tile spacers (they sink) on more sensitive rocks (in addition to ceramic media), but I still haven't determined whether or not that is any better than just using ceramic media. It worked well with obsidian though.
By the way, I only use rotary tumblers (I don't have a vibrating tumbler).
terryjh
Post by terryjh on Feb 4, 2022 12:26:44 GMT -5
I too gave up on plastic pellets. Grit get embedded in them. I also felt that the polishing energy/pressure, and the intended abrasion, gets absorbed by the plastic and not transferred to the rocks. I use all ceramic now.
Terry
