denversue
Member since October 2021
Post by denversue on Feb 15, 2022 18:57:55 GMT -5
The instructions for this tumbler are really lacking. Is this the way to set it up? Do I have to disassemble it after I put the rocks in and screw the lid on? Or do I just put the lid on top of this? When I put it on top, it doesn't go all the way down to the bowl. HELP
brybry
Enter your message here...
Post by brybry on Feb 15, 2022 19:33:06 GMT -5
I had that problem too with mine.
1- take both nuts off and remove the bowl.
2- remove the threaded rod and screw the silver nut about 1 1/2 inches up.
3- replace the rod back into the threaded hole. When it bottoms out, back off 2 turns. Tighten down the silver nut.
4- put on the bowl and tighten it down using the black rubber coated nut. Tighten until the rubber bulges slightly.
5- Add rocks etc.
6- place lid on, secure with washer and 2nd rubber coated nut.
denversue
Post by denversue on Feb 15, 2022 20:32:34 GMT -5
THANK YOU! I think my husband wrecked it now because he took a wrench and screwed everything on and now he can't get it off. The lid does not close all the way.
brybry
Post by brybry on Feb 16, 2022 4:22:57 GMT -5
Hopefully he didn't get too heavy handed and you still have a working vibe. Got my fingers crossed for ya.
jimmie
Member since August 2021
Post by jimmie on Feb 16, 2022 7:06:45 GMT -5
Nothing looks broken. Take your time. I’m sure he can get it back apart. After you figure it out , your home free.
