denversue
Member since October 2021
Post by denversue on Feb 16, 2022 16:22:59 GMT -5
Everyone here talks about adding some water to the Tumble Vibe 5. I called the company because the instructions that came with the tumbler are terrible. The guy said it is a dry tumbler, and don't add any water. What's the story?
brybry
Enter your message here...
Post by brybry on Feb 16, 2022 16:41:08 GMT -5
There is a video on YouTube on how to use it for rocks.
The suggest 2 tablespoons, I don't use that much. I let the rocks tell me how much I need. I usually start the rocks, add water with a sprayer to get everything moving, add grit/polish and adjust the water as needed to keep everything moving.
denversue
Post by denversue on Feb 16, 2022 16:47:53 GMT -5
thanks
jimmie
Member since August 2021
Post by jimmie on Feb 16, 2022 16:51:04 GMT -5
All my rocks are wet when I add them to my thumler. I add grit, then spray bottle to get it moving. Generally a tiny bit to start. It does require more water to keep it moving in the following days.too much water washes the grit off, not enough water , it’s just a rhythm section with no movement.
denversue
Post by denversue on Feb 16, 2022 16:57:59 GMT -5
thanks. How many days does it take to polish? How full do you fill the tumbler?
jimmie
Post by jimmie on Feb 16, 2022 17:01:30 GMT -5
I fill it to the blue line. I use large ceramic media, I’m mostly doing larger rocks. I do 3 or 4 days per stage, longer if it’s below 20 degrees. Don’t want to get frostbite washing rocks. It takes a little time to get it down pat, don’t stress. It’s hard to screw up rocks in the final stages.
brybry
Post by brybry on Feb 16, 2022 17:21:40 GMT -5
For a TV-5, I fill to just below the bowl rim.
denversue
Post by denversue on Feb 16, 2022 18:35:14 GMT -5
denversue
Post by denversue on Feb 16, 2022 18:36:03 GMT -5
4 days f I r each stage!? I thought it only took 1-2 days
jimmie
Post by jimmie on Feb 17, 2022 8:35:09 GMT -5
You can try one or two days. I go by what the rocks say. I like to go 4 days in final polish. I’m doing mostly larger nodules with a polished flat side. To me they take longer then regular “round” stones.
denversue
Post by denversue on Feb 17, 2022 9:24:24 GMT -5
Ok thanks
afterburnt
Member since June 2021
Post by afterburnt on Feb 21, 2022 12:35:24 GMT -5
I go just 48 hours per stage so done in 6 days 8 if I add a 1000 grit stage. So far the only things that didn't shine were Common Opal and Blue Onyx.
