badrock
Member since January 2022
Post by badrock on Feb 18, 2022 12:24:30 GMT -5
This is my stock of grit. I currently have two tumblers going that are beyond step 1. The step they are currently at is highlighted in yellow. Where I intend to go, the next steps, are in red (QT-6). This morning my 3a finished step 5 with TXP. A few nice Rainbow Ledge Agates, which were almost perfect but not quite. After a super clean out, I threw them back into the barrel with Cerium and a pinch of borax for a two week run. Fingers crossed... Please share your grit experience. How do you get to perfection? Am I missing any ingredients, grits, or polish? Thanks!
Post by rmf on Feb 19, 2022 3:09:13 GMT -5
My grit(s) of choice for rock tumbling, 46-70 coarse SiC, 120-220 medium SiC, -600 SiC for fine, Polish is MicroAluminum. I have tried Tin Oxide polish it is too expensive and you have to reuse. Cerium Oxide is also too expensive if you don't reuse. Micro Aluminum I can dump after one use, I also have used Tripoli when polishing agates. Cheap enough to use and dump. As you tumble grit breaks down so the -600 grit has 600 and finer which will breakdown to even finer. though using 1000 or 1500 might be better I have not tried them.
badrock
Post by badrock on Feb 19, 2022 16:54:15 GMT -5
Grit breakdown, 60-90 Sic, it's gone within 3-days of grinding. Cerium, worked great in my vibe, but definitely likes to leave residue in cracks. I'm experimenting with it in the tumbler again. Thanks!
badrock
Post by badrock on Feb 20, 2022 18:27:48 GMT -5
I pulled the Rainbow Ledge rocks early. Tumbled with Cerium Oxide. There are several I really like. Here's one of them.
