Post by Son Of Beach on Feb 18, 2022 18:04:54 GMT -5
Do these just pop off and if so do they slide back on? Or do they need a special tool of sorts?
brybry
Enter your message here...
Member since October 2021
Post by brybry on Feb 18, 2022 18:06:39 GMT -5
Super tight friction fit. I haven't found a good way to take them off.
Post by Son Of Beach on Feb 18, 2022 18:17:23 GMT -5
Super tight friction fit. I haven't found a good way to take them off. Yea that's what it looks like. Worried I'll damage it in the process.
brybry
Post by brybry on Feb 18, 2022 18:20:24 GMT -5
I usually do myself. If you have a pair of pliers and a small hammer, you open your pliers, lightly clamp them under it and tap the rod down with the hammer.
Post by jasoninsd on Feb 18, 2022 18:30:47 GMT -5
When I've had to pop those off other things, if I can, I put channel locks around the shaft, then redneck brace it against something then pop the top of the shaft with a hammer. You don't grip with the channel locks, they're just there against the washer. If this doesn't make sense...don't try it! LOL
If I have room to put the shaft in my vise, I do it that way instead of using channel locks. Again, I'm not tightening the vise...
Post by Son Of Beach on Feb 18, 2022 19:29:12 GMT -5
Right on. Thanks for the responses jasoninsd , brybry . At least I know it's doable now
brybry
Post by brybry on Feb 18, 2022 19:41:50 GMT -5
Your welcome. Worst case is you have to go to Lowe's or HD to get new ones.
