nursetumbler
Member since February 2022
Post by nursetumbler on Feb 27, 2022 13:19:38 GMT -5
Hi all I was trying to figure out how to sign up for cloudinary so I can post photos but guess I am just not bright enough to do it, my husband who even read over the instructions and he cant figure it out. So I guess I'll just resolve to asking questions.
Post by Toad on Feb 27, 2022 16:21:44 GMT -5
I use imgur. Pretty easy for me and I'm an old man.
Post by realrockhound on Feb 28, 2022 4:12:42 GMT -5
Go to cloudinary, select get started. From there fill in the boxes, email etc. then at the end select create account
rewdownunder
Member since March 2012
Post by rewdownunder on Feb 28, 2022 23:04:39 GMT -5
I have found the best way to set up Cloudinary is to print out the instructions in the tutorial on paper and just follow them one at a time and check them off as you go. Not much thinking needed but you have to follow each instruction to the letter. once you get it done it is so easy to insert photos. We are here to help.
nursetumbler
Post by nursetumbler on Mar 1, 2022 3:10:17 GMT -5
I have found the best way to set up Cloudinary is to print out the instructions in the tutorial on paper and just follow them one at a time and check them off as you go. Not much thinking needed but you have to follow each instruction to the letter. once you get it done it is so easy to insert photos. We are here to help. Thank you rewdownunder
