phixer
Member since January 2022
Post by phixer on Feb 28, 2022 16:19:29 GMT -5
OK I should have placed a warning here first.
"Don't try this mod it's unproven!"
It looks good and you would think it should work well but the rods are a very soft metal and the lateral movement will destroy them. I ran a load for a week and the rods have a lot of wear where the bearing are. So back to the plastic bearings after cleaning up the rods and back to the drawing board.
Well I came up with a solution for the plastic bearings on the model B. The 608ZZ bearing holder is printed out of PETG and I printed a modified standard plastic bearing to use as a jig to center the shaft to drill mounting holes. The shafts were just long enough to use the original clips on the shafts. It will be a bit more complicated to change the belt but it's not bad. Oh and I also found these silicon feet that almost completely kills the noise being transferred to the self.
brybry
Enter your message here...
Member since October 2021
Post by brybry on Feb 28, 2022 17:40:06 GMT -5
Bad linky
phixer
Post by phixer on Feb 28, 2022 19:48:55 GMT -5
Got Cloudinary working and got rid of bad link
brybry
Post by brybry on Feb 28, 2022 19:57:01 GMT -5
Ok, that's cool!
Brian
Member since July 2020
Post by Brian on Feb 28, 2022 22:00:54 GMT -5
Nicely done! It looks like it could have come that way from the factory with a design and install that clean.
