Post by Starguy on Mar 8, 2022 18:55:54 GMT -5
Delivered today. Two round bits came with the machine. The groove cutter was a separate purchase. I see some groove wraps in my future. I’m pretty impressed with this machine.
Post by perkins17 on Mar 8, 2022 19:10:12 GMT -5
That's awesome! I saw Drummond Island Rocks' tutorial on this and thought it was really cool. I should add one to the arsenal. Maybe you could use those round bits to get cabs preformed? Just a thought...
Post by rockjunquie on Mar 8, 2022 19:13:03 GMT -5
Yup, I'm not even psychic and I see groove wraps in your future.
Post by Starguy on Mar 8, 2022 19:16:54 GMT -5
You’re funny Tela rockjunquie I know it’s not real wrapping, but it’s a way to start for me.
Post by rockjunquie on Mar 8, 2022 19:29:21 GMT -5
You’re funny Tela rockjunquie I know it’s not real wrapping, but it’s a way to start for me. It's not real wrapping? I don't know about that. It requires talent. Wait til you do a few, you'll see.
Post by jasoninsd on Mar 8, 2022 19:31:45 GMT -5
That's awesome! I saw Drummond Island Rocks' tutorial on this and thought it was really cool. I should add one to the arsenal. Maybe you could use those round bits to get cabs preformed? Just a thought... I've tried to use mine to shape my preforms. I've found using the edge of my trim saw blade works far better. It's faster and doesn't chip the preforms as badly... That was one of the main reasons I bought it as I thought I'd use it for shaping preforms. I had a tendency to get "caught" in the motion around the bit, which resulted in a "divot" in the perimeter of the cab... You’re funny Tela rockjunquie I know it’s not real wrapping, but it’s a way to start for me. First...CONGRATS!! That's really awesome! Second...it IS real wrapping...just groove wrapping!
Post by Starguy on Mar 8, 2022 19:37:19 GMT -5
I’ll be tapping your brain for help. I ordered some square 22 gauge copper from KN today.
Thank you for helping me.
Post by liveoak on Mar 8, 2022 19:38:04 GMT -5
Excellent purchase- I've yet to try grooving with mine - but it's great to shape a pre-form. Keeps the cab flat on the table.
Have fun with it.
Patty
Post by hummingbirdstones on Mar 8, 2022 22:08:22 GMT -5
Congrats on Gryphon! You'll have all kinds of fun groovin' and wrappin'.
Post by Starguy on Mar 8, 2022 23:58:50 GMT -5
Thanks everyone jasoninsd gave me a great ideas for managing the depth of the cut. My wife wants to wrap some of my rocks. She’s the artistic one in the family.
Post by hummingbirdstones2 on Mar 9, 2022 9:09:43 GMT -5
Nice addition to your arsenal there. I'm sure Jason has you dialed in on groove depth setup, but I'm adding photos of the rig I did for Robin.
Flat bar is notched just enough for the spindle. Can be attached with small bolts and washers on each end. I'd epoxy bolt heads to a piece of flat stock, then stick the bolts up through the table.
Depth set by using an allen wrench to get it close enough. Feeler gage to set height in girdle.
Post by liveoak on Mar 9, 2022 9:45:38 GMT -5
I feel really dumb asking -
but what is the purpose of the bar ? The bit has a set screw to the shaft to allow you to set height.
Please explain.
Post by hummingbirdstones on Mar 9, 2022 9:51:41 GMT -5
Please explain.
The bar is for the depth of cut of the groove. When you groove wrap you want the wire to be flush with the outside of the cab when it is wrapped. Too shallow a cut and the wire sticks out, too deep and and it gets swallowed up and you can't see it.
Post by Starguy on Mar 9, 2022 10:08:37 GMT -5
hummingbirdstones2 Thanks Vince. What a simple but elegant idea. I will set mine up like that. how thick it’s the bar?
Post by liveoak on Mar 9, 2022 13:58:01 GMT -5
Thank you Robin for explaining- After I posted my question ( and stared at your pictures longer),I came to the realization that that HAD to be what it was for. Thanks for the confirmation.
Post by hummingbirdstones2 on Mar 9, 2022 19:21:48 GMT -5
Not ignoring you Starguy - I just got home from the day job.
I think that was a piece of .032" brass I had on hand. Rigid enough to be functional.
To set the groove depth precisely (a necessary step - as the beautiful little jewelry maker here told me) use a piece of the same wire as your wrap.
Post by Starguy on Mar 9, 2022 20:57:39 GMT -5
hummingbirdstones2I’m heading to the hardware store tomorrow. Thank Robin for the tip on he proper depth. I have some 22 gauge copper coming from Kingsley North. I have a couple thick slabs set aside for my first attempts.
Post by Starguy on Mar 10, 2022 19:38:06 GMT -5
I got the fence for controlling the depth of groove cutting completed. I ended up using some pipe hangar strap I had laying around. The strap is .024 inches thick. I may need to chamfer the backs of preforms after they are grooved. I think the preforms may ride up onto the fence if they are chamfered. Picture 1 shows the fence. I will attach it with machine bolts through the deck. Pictures 2 and 3 show the depth adjustment range. I should be able to cut a pretty deep groove or a very shallow one. I can’t wait to try it. Thanks jasoninsd and hummingbirdstones2 for giving me some ideas to control the depth. I appreciate your expertise.
Post by jasoninsd on Mar 10, 2022 19:45:57 GMT -5
I really like that Brent! You really do have a wide range with regards to depth! I can't imagine you'd need it any deeper that 18g or 16g width...but if you do, you've got the ability. I can't wait to see your first groove wrap!
Post by hummingbirdstones on Mar 10, 2022 19:52:10 GMT -5
Starguy you done good! Looks great. Now I may need to get Vince to make me one that is adjustable like that!
