Post by Starguy on Mar 12, 2022 11:39:23 GMT -5
I opened one of the 12 pounders yesterday. The 12 pounders run coarse grit only. It was immediately apparent that something was wrong. There was no slurry only gray colored liquid. I dumped the barrel and rinsed the rocks. Even without grit, the newer rocks were somewhat rounded. That surprised me a little. What really surprised me was how shiny the rocks were. It’s almost as though they had been in pre-polish. Here are a couple photos. The rocks were photographed dry.
Post by perkins17 on Mar 12, 2022 12:18:30 GMT -5
We've all been there... Just be glad you didn't forget water! That'd be a nasty cleanout. It's cool they got shiny... I wonder why.
Post by Starguy on Mar 12, 2022 12:23:23 GMT -5
perkins17That’s a real head scratcher. They ran for nine days. The last thing I would have expected was shiny rocks.
lparsons
Member since April 2020
Post by lparsons on Mar 12, 2022 15:26:57 GMT -5
That was a definite surprise 🤣I’ve heard of people doing that intentionally if the rocks were very dirty, and maybe some rocks getting the sharp edges rounded off a little, but never any shine.
Mark K
Member since April 2012
Post by Mark K on Mar 12, 2022 17:32:36 GMT -5
I did it on purpose with some AZ wood. Turned out really nice. Actually, I think I may have put them rough, in final polish. Not real sure now.
Post by rmf on Mar 12, 2022 20:50:15 GMT -5
In mining: "Autogenous grinding is a process of grinding ore in a rotating cylinder, using large pieces of the same ore. Autogenous mills operate mechanically like ball mills; however, the media used for grinding differs. Simply put, in autogenous grinding, the media is also the material that is being ground, whereas in other milling methods steel or porcelain balls are used as media." www.azomining.com/Article.aspx?ArticleID=1083
Post by jasoninsd on Mar 13, 2022 0:04:33 GMT -5
Well...I thought I was the only one who did stuff like this! Pretty fascinating with regards to the shine those got!
quartzilla
Post by quartzilla on Mar 13, 2022 8:43:21 GMT -5
Just don’t forget the rocks😉
