Post by stardiamond on Mar 23, 2022 15:58:59 GMT -5
My first machine had a big leather pad on the end and was told to use tin oxide. It only had two hard wheels and the sanding was done with a lapidary belt sander. A lot of undercutting on some material so I decided to go all diamond with a Genie.
100k diamond paste does a good job on most of the material I work on. I wasn't happy with the polish on some stones probably because I need to add more paste to the canvas pad. I decided to try tin oxide on some of the stones and there was improvement. I added paste to the canvas pad and that solved most of the problem.
A couple of the sites I visited mentioned Zam so I bought a tube from Amazon. I thought I would make a slurry with it and bought some lambs wool covers to put over an old canvas end lap pad. The Zam arrived and it was a stick that needed to have shavings taken off of it. I put them in some water and they just floated. I dumped the contents into a soft microfiber cloth and used a cab to work it in. It did a nice job on some Lucin variscite cabs, an improvement over what I had with the diamond paste. The crandallite cabs already had a good polish with diamond paste and the Zam made no significant improvement. The same with other polished agates and jaspers.
One comment I saw about Zam was the person liked it so much they were dumping diamond paste. I haven't found any info about using Zam on an end polisher, so I'm keep using diamond and have another tool available.
Post by Peruano on Mar 23, 2022 17:20:18 GMT -5
Try it on a muslin wheel. It is chromoxide in a paste and hence not water soluble and works best when it heats the stone enough to melt the wax a bit and expose the oxide. It can be aggressive so use briefly on soft material and indulge a bit more on agate. If you have pits the green wax will embed and stay conspicuous until scrubbed judiciously.
Post by stardiamond on Mar 23, 2022 17:35:04 GMT -5
Thanks for your input.
I understand about the pits. One of the reasons I went to diamond was to not have to get the polish out of pits. Next time I make a lapidary supply order I will get another muslin pad. The diamond paste works into the pad fairly easily. The Zam will require more effort. I can deal with hand polishing for now.
Post by stardiamond on Apr 1, 2022 12:54:49 GMT -5
I don't know how well the dust will stay on the pad. Not like paste. I saved the dust that fell off.
Post by stardiamond on Apr 1, 2022 14:19:46 GMT -5
Someone suggested holding the zam stick against the revolving pad frequently. I try to work dust free. Everything cut or ground with water or oil. I work outside and the dust mess isn't an issue. I'm not keen on the idea of wearing a dust mask when polishing. It also seems like a lot more waste of the material.
Post by hummingbirdstones2 on Apr 1, 2022 21:48:44 GMT -5
dshanpnw
Member since December 2020
Post by dshanpnw on Apr 5, 2022 7:00:59 GMT -5
Hello, I was going to use Zam to polish some agates because I was having some problems on certain ones using diamond discs. I thought about giving Zam a try, but read it is best used on softer stones, so I'll save it for when I have to polish some sunstone or lapis, or something softer. Thanks for posting.
Post by stardiamond on Apr 5, 2022 15:16:40 GMT -5
It helped with Morgan Hill when there aren't vugs. I tried it on Tahoma and could see the difference. I used previously polished cabs and did it by hand with muslin pad I charged.
