jimmie
Member since August 2021
Post by jimmie on Apr 3, 2022 5:22:45 GMT -5
As long as you turned it on, it’s full speed ahead
quartzilla
Member since April 2020
Post by quartzilla on Apr 3, 2022 9:28:16 GMT -5
Your on the right track. Maybe just let it run about 8 or 9 days with the extra scoops of sic. On a 12 I’d use 12 table spoons and run a week.
Post by jasoninsd on Apr 3, 2022 11:25:17 GMT -5
I think Jimmie and Quarts pretty much nailed it. Congrats on the 12 pounder!
Benathema
Member since November 2019
Post by Benathema on Apr 3, 2022 16:10:25 GMT -5
As long as you turned it on, it’s full speed ahead Dang it, now I gotta run back home and see if I plugged it in. This thing requires electricity!? Where do I get that!? The hole the rat lives in, or... ??
hypodactylus
Member since July 2021
Post by hypodactylus on Apr 3, 2022 16:23:48 GMT -5
I know everyone is going to have their own process, but it sounds like you've got a good start!
For reference, I use around 3 cups (48 tbsp) of 35/70 SiC grit in my Lortone QT12 when I have a mix of large and small hard rocks (Agate, Jasper, etc) in stage one. The grit is broken down/spent by the time I do the cleanout after 6 or 7 days. If the rocks are generally smaller and/or softer, I would use less grit.
I find that larger tumblers have more tumbling action/power and break down grit faster; thus requiring more to keep the grind going (especially in stage 1). The same is true for larger rocks.
dshanpnw
Member since December 2020
Post by dshanpnw on Apr 3, 2022 18:48:12 GMT -5
Hello Blockhead, sounds like you did everything just right. Now you just wait a while. Good choice of rocks to start with.
Doug
