Post by fernwood on Apr 10, 2022 2:11:25 GMT -5
Apache Tears that is. Forgot the size reference, but the larger ones are about ½-3/4"” wide. Plan on putting some of them in the cage style pendants. Others will be for earrings and rings.
Post by jasoninsd on Apr 10, 2022 8:40:31 GMT -5
Definitely nothing to cry about in that batch Beth!
Post by fernwood on Apr 10, 2022 9:33:51 GMT -5
Definitely nothing to cry about in that batch Beth! Thanks. Third tumble of Apache tears and this is the best ever. They are a lot more shiny than the photo shows.
JR8675309
Member since August 2019
Post by JR8675309 on Apr 10, 2022 11:05:18 GMT -5
IDK how you did it but they're gorgeous. I'm surrounded by obsidian and it never seems to come out well for me. Keep up the good work!
Post by vegasjames on Apr 10, 2022 14:40:51 GMT -5
Those came out great.
catskillrocks
Member since July 2008
Post by catskillrocks on Apr 10, 2022 18:21:35 GMT -5
Those came out really nice Beth.
quartzilla
Member since April 2020
Post by quartzilla on Apr 10, 2022 20:14:10 GMT -5
The photo is fine, they are very shiny. I’m not ready to try these yet lol.
Post by fernwood on Apr 11, 2022 6:35:22 GMT -5
IDK how you did it but they're gorgeous. I'm surrounded by obsidian and it never seems to come out well for me. Keep up the good work! Final polish: Tin Oxide. 75% stage specific, plastic tumbling pellets, 25% Tears. 1 lb barrel. Chicago Electric tumbler for all stages. Started with a 3 lb. barrel.
JR8675309
Post by JR8675309 on Apr 11, 2022 6:55:34 GMT -5
IDK how you did it but they're gorgeous. I'm surrounded by obsidian and it never seems to come out well for me. Keep up the good work! Final polish: Tin Oxide. 75% stage specific, plastic tumbling pellets, 25% Tears. 1 lb barrel. Chicago Electric tumbler for all stages. Started with a 3 lb. barrel. Oh wow, very cool. Thank you for sharing your knowledge. On a side note, I've been thinking of adding a HF tumbler to the mix. Sounds like it works for you.
Post by fernwood on Apr 11, 2022 7:15:42 GMT -5
Final polish: Tin Oxide. 75% stage specific, plastic tumbling pellets, 25% Tears. 1 lb barrel. Chicago Electric tumbler for all stages. Started with a 3 lb. barrel. Oh wow, very cool. Thank you for sharing your knowledge. On a side note, I've been thinking of adding a HF tumbler to the mix. Sounds like it works for you. It works great. I had some wonderful advice here on how to modify it a little before using. Just changed to an O-ring style belt, adjusted belt tension. I oil the bearrings monthly with carbine oil.
JR8675309
Post by JR8675309 on Apr 11, 2022 8:00:27 GMT -5
Oh wow, very cool. Thank you for sharing your knowledge. On a side note, I've been thinking of adding a HF tumbler to the mix. Sounds like it works for you. It works great. I had some wonderful advice here on how to modify it a little before using. Just changed to an O-ring style belt, adjusted belt tension. I oil the bearrings monthly with carbine oil. Good advice.
